hauling with mast stepped but lowered
I saw this guy driving through town down to the public dock.
I could not believe he drives around with his mast stepped like this, with 12 feet of mast hanging out. (Not to mention he had no red flag.)
I talked to him and supposed he must live very close by, to drive down here like that. He lives a half hour away by highway and says he's been all over the area.
He said 'Why does it surprise you?' I said 'I'd fear snapping the mast in half'. Apparently, he has no such worries.
- pitchpolehobie
Re: hauling with mast stepped but lowered
Good for him I wouldn't do it
2002 MacGregor 26X: Remedium
Tohatsu 25HP
Tohatsu 25HP
- Jimmyt
Talk about reducing your setup/takedown time...
I agree with pitchpolehobie. No way I would try that.
May be an optical illusion, but the photo appears to show the mast deflected.
Hmm interesting location for the port lights. Gotta remember to keep them closed while under way.
I wouldn’t do it as much for the metal fatigue in the mast as for the big tail swing in tight quarters. That mast is going to bounce around back there under way, resulting in cyclic stresses in the mast, especially where the crutch is. And unlike ferrous metals like steel, aluminium fatigues no matter how small the cyclic loading, so it’s all adding up while driving, as well as under way while sailing. Especially at the spreader attachment point, where the bolt holes are (stress raisers).
I pin the base to the bow rail, pin and tie it off at the crutch to eliminate side-to-side wiggling, and use a short crutch at the tabernacle. That crutch is helpful when my generous heft decides to land on the mast, right between the other two support points, due to my less-than-Fred-Astaire-like cabin roof maneuvering technique.
Tom
Be seeing you . . .
Be seeing you . . .
You are not optically deluded; I too noticed it had some serious bend.
(Hwy - I know what happened. He read the manual, where it says "a 4 degree rake in the mast" and he assumed that was from horizontal. )
Yeah. I'm the opposite of "Playa Maya". I run a dockline from the starboard fairlead up to crutch roller and down to port fairlead - you could pluck it like a guitar string - to be absolutely sure there is zero lateral deflection.Tomfoolery wrote: ↑Mon Sep 06, 2021 3:33 pm I wouldn’t do it as much for the metal fatigue in the mast as for the big tail swing in tight quarters. That mast is going to bounce around back there under way, resulting in cyclic stresses in the mast, especially where the crutch is. And unlike ferrous metals like steel, aluminium fatigues no matter how small the cyclic loading, so it’s all adding up while driving, as well as under way while sailing. Especially at the spreader attachment point, where the bolt holes are (stress raisers).
TIL what a tabernacle is....
- Jimmyt
DaveC426913 wrote: ↑Mon Sep 06, 2021 4:56 pm (Hwy - I know what happened. He read the manual, where it says "a 4 degree rake in the mast" and he assumed that was from horizontal. )
- Jimmyt
Today I learned what TIL is...
Would you like a Mormon choir to go with that tabernacle?
- WinSome
And the good thing is all low hanging hydro wires will just slide up and over!
Their,s a name for that style of boat hauling
it,s called "The Xpress Brain Dead Maneuver"
It require,s a great deal of skill starting with #1 Stupidity, #2 having a brain transplant into ur butt , #3 Zero IQ level , #4 total disregard for safety & other people,s lifes or injury , #5 Lacking any skill set or knowledge, #6 Has no Idea of the meaning of what "Common Sense" means !
Other than that he,s breaking the law #1 insecure load #2 over length structure with no permit , no signs, no emg. lights #3 no escort vehicle's, #4 No approved Route permit #5 requires a commercial grade A drivers lic, for this move so basically driving unlicensed #6 unlicensed vehicle requires commercial plates in that towing configuration
so if he gets caught everything gets impounded , he loose enough points on his driver,s Lic for a years suspension, about $15,000 in fines , towing fees x two $$$$, impound fees x two $$$$, lawyers Fee,s $$$$$, & god forbid if someone gets seriously injured or killed Jail Time !
So I,ll just say he,s a D/F or Daft , Hope he,s not a member on here we don,t need that kinda personality giving us a bad review
If he is a member on here I hope he reads this & has a frickin Brain fart then smartens up
- WD
Well, IF i had any doubt while reading this i believe Highlander pretty well closed the barn doors!
Cheers eh
Cheers eh
- Jimmyt
Highlander tells it like he sees it. I like that. You never have to ask him "what's you honest opinion", cause that's all you're gonna get. And usually both barrels. Love that whacky guy.
