Restore shine to the black permanently
- panda
What's the best way to restore shine to the black gelcoat stripes surrounding windows preferably permanently? I used ZEP acrylic floor polish this spring at it looked good for two months, and then it started to fade again. Did anyone tried Nuglass or something like that? Need something that would last for at least a year.
- Stickinthemud57
Re: Restore shine to the black permanently
I had good results with Meguiar's 49 Oxidation Remover. Made to remove "moderate oxidation, water spots, and scratches from gel coat". After that, apply a good coat of UV resistant marine wax. You should be good at least for the season if not the year.
Early this Spring I binge-watched this guy's videos how to detail a boat.
He does this for a living and seems to know his stuff.
So I bought this Jescar Power Lock+ he uses. There is a link below his video.
The stuff is $32 a bottle and I used about half a bottle on the boat and one of my cars. I also bought a dual-action random orbital polisher (not the expensive one he uses).
For the first time in 10 years, my boat's gelcoat did not fade over the season. The black is still black and the blue hull looks great.
He claims it prevents water spots because it sheets the water off rather than bead. Drake is my hero. It works great.
- panda
Thanks for this, Russ!
Russ wrote: ↑Mon Oct 04, 2021 6:04 am Early this Spring I binge-watched this guy's videos how to detail a boat.
That's great RussRuss wrote: ↑Mon Oct 04, 2021 6:04 am Early this Spring I binge-watched this guy's videos how to detail a boat.
So now that u have practised on ur boat & know how's it done why don,t u come over to my place & practise some more on my boat as it,ll b coming out shortly for maintenance
Jus sayin That's All " Practise makes perfection" as they say
The problem with the black around the windows is due to MacGregor trying to save a couple of bucks. It is a gelcoat issue that a buff and wax will not solve over the long haul.
If you add another coat, it will glisten for years. Thankfully, it is a small area and you can do it easily enough with the roll and tip method.
- panda
"roll and tip" - can you send me a link to the instructions?
PSNA wrote: ↑Thu Oct 07, 2021 9:43 am The problem with the black around the windows is due to MacGregor trying to save a couple of bucks. It is a gelcoat issue that a buff and wax will not solve over the long haul.
- NiceAft
I gave up years ago.
I finally just painted over the raccoon stripes.
It’s been quite a few years now, so it may be time to do it again next spring.
Benjamin Moore impervex latex high gloss enamel (black). It’s a thin paint, so be certain to tape well.
Ray ~~_/)~~
- kmclemore
Just google "Roll and tip painting"... you'll see many videos and descriptions. Basically, one guy rolls it on with a foam roller, and the other follow behind and brushes it flat. Leaves a nice finish, when done properly.
- panda
Found it - thanks!
