Jeff Ritsema wrote:Moe,
When you refer to the motor being trimmed down, is this in reference to pushing the bow down? Does this hull configuation function best and safest bow up? There have been numerous references in the forum to efforts to bring the bow down when powering, I presume for improved visibility, but doesn't this actually introduce a risk and loss of performance, having the bow down to an extreme?
Appreciate your thoughts.
Jeff, you are exactly right. The loss of stability
could be related to the bow being forced down which causes the bow to plow. Many Mac owners adjust the motor down (in) to the extreme in an effort to bring the bow down. At low speeds this is not a problem, but then you don't really need to bring the bow down at low speed. At high speed, the boat becomes unstable in any sort of wave or wake action if the bow is being forced down.
The best thing you can do is trim the motor
out, letting the bow come up. Continue trimming the motor until the cavitation plate on the motor is parallel to the surface of the water coming out from behind the boat. Yes, the bow will rise, but the ride will smooth out, and there will be very little loss of stability when encountering wake or wave action.
I know this is counter to what most Mac owners do, but it is absolutely vital that you trim the motor properly to avoid loss of control. If you need to improve visibility, stand up, or sit on a tall cushion or a fender. Of course, you could always slow down to bring the bow down, but what fun is that?
