26s rudder castle opening
chadwiseman
Post by chadwiseman »
My rudder castle opening seems to be about 1.25 in, but the standard rudder from bwyachts or rudder craft is about 1.75”.. The previous home made rudder was only 1 inch.. I’m wondering if there should be enough give in the bracket to accept this standard size rudder.. Thougths?
Stickinthemud57
Re: 26s rudder castle opening
Post by Stickinthemud57 »
I replaced my 26s stock rudder with an airfoil rudder from RudderCraft and did not run into any issues. In fact I added a 1/16" piece of Lexan on either side of the rudder inside the castle to allow me to tighten the pivot nut (so as to minimize slop) without making it too hard to raise or lower.
chadwiseman
Wondering if anyone ever replaced the steering post. Looks like the bolts go into a cavity that I can’t access ..
chadwiseman
chadwiseman
Thanks, has anyone used any other materials to make up some of the gap between the rudder and the castle opening?
Stickinthemud57
This post has kind of languished. I will make a point to take a look at my rudder post and see what you are talking about. I have never had the need to remove mine.
