We set out on my 2005
Raised the new main sail with the replacement #4 batton we lost on Elk River, from BWY (thanks for the fast shipping Todd). Added the boom vang straight away which helped flatten the sail and keep us out of the 30 degree heel territory.
Realized the Halyard was twisted (fixed while underway), and couldn't get it taught... Also realized first hand why bowlines are not used, despite reading in the instructions to not use bowlines! Will try a halyard knot next season.
We used the jib furler for the first time and sailed the jib when the wind died down a bit, but we were right to keep it furled. That system worked perfectly and as expected. My furling drum it set 90degrees to face the port side, this is a problem I will correct in the Spring.
We also practiced reefing this time out and it worked perfectly. We saw speed and heel decrease from 4.5mph/15-20 degrees to 2.5mph/5-10 degrees.
One oddity was raising the main once it was on the first reef point, still couldn't get it taught... Will follow the tips in other posts here to run a slide up and down and look for pinch points or something. I even used a block at the of the brackets (all BWY sourced upgrades) for extra mechanical leverage and we were certainly in the irons, but it wouldn't get taught...
Here are a couple of quick videos that show the rigging:
Pretty Accurate Wind Forecast:
We would lose wind when going behind the island and it would hit like a brick when we were out of it... overall a very exciting day!
