Hello
About to buy a 26S and will be putting a new engine on it.
What SHAFT LENGTH works with the 26s?
David
MacGregor 26S motor leg length?
massnspace
Re: MacGregor 26S motor leg length?
Go to this thread and send either an e-mail, or a PM to chumpy36 (he has an S) and ask your question. He may be the one who can answer
https://macgregorsailors.com/forum/view ... hp?t=29334
Chumpy36
You need the long shaft version of whatever motor you get. Generally speaking, long shafts are about 20 inches long. Extra long are 25 while short shaft is around 15 inches.
I can measure both of them on mine if you would like. I haven't actually had either in the water with the boat but previous owner said he used both.
- kenfyoozed
- Sailboat: MacGregor 26D
I haven't had mine in the water either but in my research I found the 25" is what I needed with my 26D.
- Stickinthemud57
25" shaft, for sure.
This thread reminds me of the time that I had to use a 20" outboard on my 26S (Tohatsu M8B was in the shop) to get it around from the launch ramp to my slip. I and the Admiral had to stand on the transom just to keep the prop in the water!
- BillyBobV
I put a Mercury 5hp Sail Power outboard on my 26S last year and had no problems with it. It's a 20 inch shaft. Works fine moving the boat around comfortably. A little slower than the 10 hp, now dead 1996 Evinrude but still okay. If you're in a big hurry get a 26x or m.
https://onlineoutboards.com/products/20 ... oard-motor
Not promoting the seller, just showing the technical information.
Bill V
Areion
1991 26S
Areion
1991 26S
KingRichard
I have a 91S, do not get an engine that isn't an extra long shaft (25"), assuming your using the original transom mounting. Mine came with an 8hp Johnson Sailmaster, it's a 25". On really rough seas it would come out of the water, I can't imagine a 20" would work but for maybe motoring around a calm marina. With a 20" the water wouldn't move past the hull right in reverse either, total mess for getting off a beach. I just got a 4-stroke, so the original engine is for sale, actually runs great, just can't use a 2-stroke on Tahoe.
