Hi Wyb2!
Y’all must had some
beach
time!
Now looking at your bow and trunk picture it would apprear to have chewed through at least the outermost layer(s) of da fiberglass as well as all the gel coating.
I would suggest a multi layer strip repair after stripping back about 3-to-4 inches either side of centerline.
- Wet the base surface with non-waxing polyester resin (NOT epoxy)
- Apply a 2 inch woven fiberglass ribbon
(It can be bought that way with woven edges so the cloth stays together vs. turning into a gawdawfulmess of loose fibers. I know that there are a couple sources where one can get this but one that comes to mind is:
NEZUIBAN Fiberglass Cloth Tape, E-Glass 6 oz Plain Weave Glass Fiber Cloth for Repair and Reinforcement, Heat-Resistance and Insulation 2 inches Wide by 50 Yards (5cm x 45m)
- Repeat process while still tacky to apply two more layers for a total of three layers.
- Sand edges smooth to lightly blend to hull surface
- If you still want to apply EPOXY resin do it as a top coat after sanding the polyester …. Then lightly sand to blend
- Apply thin Gelcoat layers (3ish) sanding between coats to build up thickness and to blend in surfaces.
That will get your fiberglass repaired and give enough gelcoat to act as a wear surface. The epoxy really isn’t much (if at all harder or more wear resistant than polyester resin whereas the gelcoat does have that capability due to the ceramic content.
Good luck and have fun!
Best Regards
Over Easy
