Stop a few times and check it for the first hour to make sure the hubs are staying cool and there is no excessive play.Macwanted84 wrote: ↑Sat Apr 08, 2023 7:18 pm Thanks fellas! I called a gearhead buddy of mine, who helped alleviate some of my paranoia. I said if you put new tread on it, and the bearings are packed with grease, and the brakes aren’t dragging, squealing, or making a racket, the likelihood of them seizing and you rolling over 12 times is extremely minimal.”
Thank you for the advice about the coupling in the receiver. I’m hoping that’s all it was.
I am using a 2 inch ball.
I’ve also eaten, and that seems to make everything better. Especially after a day on your back of the advance AutoZone parking lot in Muskegon.
I’m sure you’ll be fine. You’ve given it a good bit of thought and taken several precautions. A lot of guys would have coupled it up and taken off - choosing to deal with problems as they come up.
Check your bunk wood for integrity. Make sure the hatch, anchor locker, and companionway washboard are securely latched. And take a pic when you get her home. Safe travels! You’ve got this.
