Hi all. Like many of you, I've thrown the tarp on my
and declared the season over.
I have one of those big custom tarps from BWY and it's ok, but I find that it pools water from the snow and I end up having to climb up and remove insanely heavy iceberg chunks of ice several from the tarp several times during the winter - or at least I do that because I worry that all that weight on top of the tarp will bend the mast or cause some other type of damage. And it's complicated by the fact that I store it at our cabin property which is about 4 hours away and gets a TON of snow (my dang HOA won't let me store it here
) so I can't exactly walk outside and brush the snow off every day.
Obviously there are some solutions to the problem if money weren't an object:
- I could shell out money to store it in a storage place
- I could build a garage/structure to store it in
But I'm curious if any of you find yourself in a similar situation where you get significant snow, store your boat under a tarp, and have had to deal with those weight concerns. I suspect I could fashion some kind of braces or something to prop the mast up off the deck, sliding hatch, and cockpit areas and that might help prevent the mast from flexing, getting bent or worse. But there are probably other things to be concerned about too.
I'm curious to hear what some of the rest of you do
