kurz
Posts: 1307 Joined: Mon Dec 06, 2010 9:07 am
Post
by kurz » Wed Feb 21, 2024 4:17 am
Hello,
Yeterday I am noticed that the block of my MRS
is completely not working anymore. It does not turn under load. The bearings are cracked.
What kind of block shall I buy? What loads? What kind of bearing?
Thanks all
Kurz
Posts: 8329 Joined: Thu Oct 11, 2007 12:01 pm
Post
by Russ » Wed Feb 21, 2024 5:19 am
Can you post a photo? My MRS has no blocks. It has a winch but not block.
leefrankpierce
Posts: 243 Joined: Fri Oct 06, 2017 5:13 am
Post
by leefrankpierce » Wed Feb 21, 2024 6:43 am
Sounds like the halyard has been setup to run back to the cockpit.
Much more convenient than running up to the mast, but probably not stock.
EDIT:
Mast Raising System, sorry I thought the MRS was the name of your boat!
I am sure any reasonably sized block should do it.
My system has multi-pulley blocks for more mechanical advantage.
Looks like a left over boom sheet setup.
leefrankpierce on Wed Feb 21, 2024 6:31 pm, edited 1 time in total.
26X in Dallas Fort-Worth area Texas
Slip at Eagle Mountain Lake
Posts: 6728 Joined: Tue Feb 01, 2005 7:28 pm
Post
by NiceAft » Wed Feb 21, 2024 1:25 pm
This is the block on my MSR, and I do not see any identifying numbers.
kurz
Post
by kurz » Thu Feb 22, 2024 2:45 am
Thanks NiceAft, Yes, it is exactely this block. It has kind of bearings inside.
I could also watch the line. What load can the line hold (braking loads)? I think it is a cheap line.
Or the winch...
Post
by Russ » Thu Feb 22, 2024 9:15 am
NiceAft wrote: ↑ Wed Feb 21, 2024 1:25 pm
That's it! My memory is failing. That's the block on mine also.
Roger wasn't known to install top shelf hardware on our boats. Probably why Kurz has failed.
I would replace it with a decent single block from any chandlery.
Something like this
https://www.westmarine.com/lewmar-50mm- ... 61718.html
kurz
Post
by kurz » Fri Jun 07, 2024 5:09 am
Finally I installed a block 2000/1000kg, somewhat bigger diameter than original.
Had good feeling.
Also the tube bents little, so I put all kind of tube inside the original tube to make it stronger.
Worked fine so far...
OverEasy
Posts: 2915 Joined: Mon Sep 28, 2020 11:16 am
Post
by OverEasy » Fri Jun 07, 2024 10:40 pm
Hi Kurz!
Just a quick couple of questions….
> What year of manufacture is your Mac26M?
> How often do you use your MRS ( mast raising system)?
If others want to chime in that would be great!
I’d like to get an idea of how often folks use their MRS over the years and how the system is holding up for them.
Thanks!
Best Regards
Over Easy
kurz
Post
by kurz » Sat Jun 08, 2024 3:02 am
My
is 2011
I normally trailer 2 times a year.
Roller Genoa is installed also when using MRS.
Posts: 4959 Joined: Fri Aug 27, 2010 10:00 am
Post
by dlandersson » Sat Jun 08, 2024 3:52 am
"Block"? or "pully"?
kurz wrote: ↑ Wed Feb 21, 2024 4:17 am
Hello,
Thanks all
Kurz
Post
by NiceAft » Sat Jun 08, 2024 3:57 am
I am the original owner of a 2005
. The MRS is engaged about four times a year. It too is original to 2005. As with Kurz, “Roller Genoa is installed also when using MRS”.
