Hi LeeFrankPierce!
That is a very good questions!
Our current answers are in sequence “no”, “no” and “yes, I’m pretty sure one does”
We currently have been operating in ‘cruiser’ mode as our area are tidal rivers and serpentine estuaries that we love to explore into as far as we can safely navigate. The calm waters and tidal marsh borders are abundant with wildlife such as Dolphins, Egrets, Herons, Osprey, Sea Turtles, Mantas, Deer and occasionally Alligators. Many of these areas are not really conducive to a mast, rigging and sailing unless one enjoys constantly tacking to and fro (which I’ll admit can be a whole lot of fun
) but it’s a lot of work plus takes near constant planning, anticipation and diligence which means we’re not able to lot about and enjoy our surroundings as much. So we go out and leave the mast at home.
On my ‘Future Mod Plan List’ is to make a pivoting mast pintle that will allow us to more readily raise/lower the mast to a true horizontal position, give us a full 6 ft 6 inch head clearance in the cockpit and sliding companionway, lower our vessel clearance height by several feet (to allow transit under more bridges) and to shorten our overall length when the mast is down by nearly 2 ft (which will come in handy when in tight spaces and in the marinas). Most marinas, like ours, tend to frown upon having a lowered mast extending past the end of the stern into the slipways as it poses a hazard for everyone. Part of the “Pintle Mod Plan” is to allow us to readily forward shift the lowered mast forward to or past the bow railing to even further reduce our aft overhang as well as for road travel on the trailer.
I’m pretty sure one is gonna need a back stay as there is considerable force exerted by the sail when sailing in down wind conditions in a good breeze. The back stay helps to distribute that forward moment loading which could potentially overload the side stays. On that aspect I’ve contemplated an aft arch (which would be an integral part of the ‘Pintle Mod Plan” to securely place the back stay above the Bimini/Enclosure height. Until then, if/when we do sail I’ll just lower the existing Bimini so as to attach the backstay.
Best Regards,
Over Easy
