Video change trailer bearings
One of my favorite Youtubers made a great video on changing trailer bearings.
Bonus: He has a section on changing the tires yourself.
Be Free
Re: Video change trailer bearings
Post by Be Free »
Thank you. That was probably the most informative and best organized tutorial on this subject I've seen. I have it bookmarked so I can send it to the next person who asks me how to do this (or asks me to do it for them :D ).
2001 26X Simple Interest
Honda BF40D
Nice. Thank you 8)
Russ wrote: Sun Sep 28, 2025 3:14 pm One of my favorite Youtubers made a great video on changing trailer bearings.
JamesToBoot
Post by JamesToBoot »
I always get a lot out of his videos.
Another option, especially if you don't have the tools / experience / work room / time, is to replace the whole pre-assembled / pre-installed / pre-lubed hub, and the assembled tire/rim.
As neglected as my tires and trailer are, I definitely need to do some pm, but not sure which route I will go.
Chris Fix for the win! What a great guy.
-james
Novice Sailor
'91 26S, fixer-upper, 55lb w 280ah lithium, need stern rail
Cruising Grounds: Lake Murray, youtube
Be Free
Post by Be Free »
The only things I would have done differently is that I clean up the spindles before I start on the hubs and I usually use a short 2x4 across the grease seals to finish pressing them in after they are started.
I appreciate the fact that he shows how to do it with minimal tools and then he shows how much (if any) the proper tools help with time and/or ease. That way the home mechanic can make an informed decision about whether or not to invest in the tools.
Honda BF40D
Be Free wrote: Fri Oct 03, 2025 11:53 amI appreciate the fact that he shows how to do it with minimal tools and then he shows how much (if any) the proper tools help with time and/or ease. That way the home mechanic can make an informed decision about whether or not to invest in the tools.
I wish I had seen this before I bought 4 new wheels/tires. Otherwise, I might have invested in some of those tire-changing tools and done it myself and saved buying new wheels.
I never understood how bearings worked or the "Bearing Buddies". This video demystifies it for me.
Chris has another youtube channel "Chris Fish" where he documents more boating/fishing experiences. He lives in New Jersey and his boating is in the waters where I used to sail in Sandy Hook Bay.
https://www.youtube.com/@chrisfished
Be Free
Post by Be Free »
If I had a single-axle trailer I would not have bought a manual tire changer. Since I have a dual axle I figure that I've more than paid for it with just the cost of mounting new tires.
After many years of hand-packing the bearings I purchased a bearing packer. It is inexpensive and saves a lot of time and mess. I've been servicing hubs since I got my first car and I highly recommend it and wish I'd gotten one sooner.
He explained the right way to use a bearing buddy but he did not explain what happens when you put too much grease in them - a mistake I made the first time I used one.
If you keep pumping grease into the bearing buddy after the spring is completely compressed you will either damage the oil seal (worst on a single lip seal) or cause the bearing buddy to come out of the hub. If you are lucky the bearing buddy pops off while you are pumping. I wasn't lucky.
I ended up having to replace one of my hubs in the boat ramp parking lot 150 miles from home after the bearing buddy came off on the highway. Without the cap it allowed all of the grease to run out and destroy the bearings on one spindle. Fortunately the wheel did not come off but the outer bearing was literally gone. FYI: You can make-do with even fewer tools than he used if you absolutely have to.
Now I never go on a long trip without a dedicated tool box containing everything I need to service the hubs on the road including at least one spare hub that's been serviced and is ready to swap out. I also have towing insurance if I don't want to fix it on the side of the road.
Honda BF40D
Thanks for the info on OVER charging the bearing buddies. I never realized that was a concern. I will remember this next time I attempt to add more grease.
His video also shows how to "jack" one wheel of a dual axle trailer by simply driving one of the wheels up on a "ramp".
That was a "palm slap on forehead" moment for me. I recently changed all 4 wheels and could have saved all the jacking by simply rolling the trailer.
OverEasy
Post by OverEasy »
Hi Russ!
Great complete video!
Chris did an excellent job producing that!
Especially having the cross section prop. He went the extra mile for folks! Nice!
Thank you for sharing!
Those “bearing buddies” are nice options.
Much better than the old static cups!
Chris also did a good bit pointing out the inboard grease fitting as well as the 12 month or 12,000 mile whichever comes first rule.
That’s been a good one to follow as it can help catch issues before they become problems….
Bearing in mind (pun intended) things can always go amiss in the real world even when you try to do things right, I can afully appreciate Be Free and having a spare hub ‘ready to go’ in a travel tool kit. It’s no fun being stuck!
I salvaged and refurbished the good hubs from when we had a bearing/wheel-hub failure in transit a couple of years ago.
For me it’s just nice to know I have options going forward in the future.
The ‘ramp up’ trick to raise a wheel is a technique I’ve used several times over the years with various tandem axle trailers.
Especially when they are heavily loaded. Much more stable than using a bottle Jack on the side of a roadway shoulder.
We also use that technique to ‘level’ our boat when traveling cross country and using our boat as an RV for camping.
Instead of carrying around an assortment of lumber we carry a pair of HD plastic ramps that can do the same trick.
It was really nice how he showed the bearing nut tightening process!
That was particularly well done and explained!
Again, Thanks for sharing this!
Best Regards,
Over Easy 8) 8)
NinjaTeacher
Sailboat: MacGregor 21
Post by NinjaTeacher »
Great video!
I'm guessing my new old boat trailer hasn't had a bearing job done, ever. Does anyone have a good idea of what axle size a 79/80 V21's original trailer has? If I'm lucky, I'll just repack the bearings, but I'm rarely lucky. 8) Otherwise, I'll buy a new pair of hubs and save an afternoon. Because I like to prove my pessimism by being prepared, I'd like to price out a replacement axle in case the 45yo old one is gouged up. Finally, I saw those leaf springs and wouldn't be surprised if that was in my future, too...
Thanks for any close at hand info you have to share before I try taking everything apart (research)!!
Be Free
Post by Be Free »
NinjaTeacher wrote: Thu Jan 08, 2026 7:38 am Great video!
The V21 weighed around 1200 pounds empty and probably closer to 1500 pounds in use so (ideally) the trailer would be rated 1500 pounds or more. I'd go up a bit if it were my boat. After a point more is not better. Springs that are too stiff don't work properly and you will end up with a very rough ride. There is no point in having an axle that can carry significantly more than the trailer or tires are rated for.
Even if the boat has spent it's entire life away from salt water it is unlikely that it has the original bearings or even the original axle. If the bearings have not been serviced in 45 years the hubs and spindles are likely shot. Replacing the axle and hubs along with all of the suspension parts may be your best course of action as long as the trailer itself is still serviceable. Take it all down to bare metal and replace it with known-good parts. You'll be happier in the long run.
You will may find that the placement of the hangers is your limiting factor. Springs come in different lengths and widths and those have to work with the mounting points on the trailer. Changing or moving those hangers can get complicated if you have to cut the off and weld on new ones. Assuming they are still serviceable, using the ones already attached to the frame would be a lot easier.
Honda BF40D
NinjaTeacher
Bill,
I'll let you know how bad it looks when I tear it down in a few weeks. I completely agree that safe is better than sorry!
Brian
OverEasy
Post by OverEasy »
Having recently removed and replaced virtually all the bolts, nuts, washers, & springs on out Sea Lion dual axle trailer I’d highly recommend replacement after all those years of potential neglect.
It’s ok to be a pessimist… the adverse consequences of an on the road failure or mishap is much more arduous and distressing.
With our trailer it was serendipitous that we found the spring leafs cracked and broken once we removed them. Prior to disassembly, There was no outward indication of the issue. Take advantage of the opportunities when you have them.
At one time in the distant past I had to move a for a friend’s boat that “looked” serviceable but by the time I’d driven it not more than 30 miles it had nearly become a FUBAR situation. The springs on one side fractured at the eye inside the front shackle which allowed the axle to shift diagonally catching the fender with the tire tread which then folded up locking the up tire which slew the trailer to one side suddenly which shifted the boat which broke its stern restraint strap eye which let the boat ride up on one side which strained the bow strap which somehow bypassed the winch ratchet which let the boat move aft changing the center of gravity aft which raised the bow which politely waved up, down, and sideways to attract my attention in the rear view mirror which attracted my attention to the nearly instantaneous condition of smoking tire and skewed tracking trailer that was diligently attempting to move into the oncoming traffic lane… phbbbttttt!!! So much for the ‘it’s never been a problem before’ attitude of my friend. Turns out he’d owned the boat and trailer for decades and his ‘version’ of taking care of it was rinsing it off occasionally with a garden hose and adding air to the tires….
Dealing with the incident adhoc with whatever happened to be at had on the side of a highway with next to no shoulder was an adventure… I hate adventures… :x :x :D .
Oh, and the tires on my friend’s trailer were also 20+ year old vintage that had been regularly wiped with ‘tire black’ that ‘looked’ ok…. He thought tires and stuff would last forever as long as it ‘looked’ good…. :D :D :D
Turns out when all was said and done the trailer frame was rusting out from the inside and was loaded onto a utility trailer to be scrapped.
I was lucky it didn’t get out of control or involve anyone else.
A simple hour job turned into hours of effort into the dark of night dodging cars… such adventures I can always do without. :D :D :D
Moral:
Never trust, always verify.
Replace before it breaks.
Best Regards
Over Easy 8) 8)
