Trailer Repairs - 30yo steel trailer rust
JamesToBoot
Post by JamesToBoot »
Its been a bit since my last update. Some injuries, some surgery, just now starting to get back into things:
I last left you with the boat off the trailer attempting to replace the bunks and working on the centerboard raising (see my other thread regarding the centerboard).
Well, I got a good look at the trailer: bunks were rotten and it looks like the trailer was used in salt water.
  • Took off the wheels, spare, bumper bits, lights, etc.
  • Stripped the wiring (had issues w grounding and was cracking thru to the conductor).
  • Took off what was left of the winch (first time retreaving the boat and the spindle wrenched in half from the rust).
  • Got it sprayed with rust converter acid.
  • Got several week spots rewelded and/or a doubler added.
  • Painted with Rustolium's rust converter paint (just what I had on hand).
  • New bunks made, wraped, and mounted (using 2x4 regular pine and boat bunk cloth).
  • Fixed and regreased the welded on trailer hitch jack (a cotter pin inside was broken, everything was dry and rusted).
  • Reinstalled the lights, new winch, rubber bits, wheels, etc
  • Rewired with a prewired, jacked covered loom. Fixed multiple issues with grounding (rust converter and paint did a good job sealing the metal).
We're now set for the next 30 years!!!
Putting the trailer back under the boat was much easy going then removing it; one) I had already done it in reverse, and two) I used the the winch hooked to the pull-pit to skooch the trailer back.
[pictures] no idea what I did w the pictures. Ill upload them when I find them:
The boat is finally read for the second test!!! (The first test was to see if it would float and if the water ballast leaked).
Since the first test:
  • the above trailer was fixed
  • the centerboard winch was added
  • the cotter pins were replaced with bolts (half of which were already rusted bolts)
  • other stuff I can't remember
-james
Novice Sailor
'91 26S, fixer-upper, 55lb w 280ah lithium, need stern rail
Cruising Grounds: Lake Murray, youtube
OverEasy
Re: Trailer Repairs - 30yo steel trailer rust
Post by OverEasy »
Nice boatport!
I’m envious! :wink: 8)
JamesToBoot
OverEasy wrote: Mon Jan 26, 2026 10:35 am Nice boatport!
I lucked into it. Just happened to be the previous owners of our house had an RV port.
-james
Novice Sailor
