Great write up!
Nicely done!
Most of the stuff I’ve had the opportunity to deal with in regard to commercial recreational consumer products are ‘native’ 12 VDC as it’s the most common source of power and suitable for most of the sourced sub components readily available. Even with the widespread availability of DC-to-DC converters many (budget) manufacturers still use a dropping resistor to lower voltage from 24 VDC to 12 VDC as its reliable and cheaper.
I have noticed that many of the manufacturers, when they offer a 12 or 24 VDC option on the same unit, will have the AC transformer adapter output set to the ‘native’ voltage. So that could be a clue if someone was interested in finding out what they might be dealing with. Not a guarantee, just and indicator.
Glad Russ mentioned the effect of wire gauge and length of wire run, both to and from the battery to the device. Some DC wiring systems have negative side return runs different than the positive side supply runs. The total length of the complete wire run from the battery and back will determine the effect on line power losses. The larger the wire diameter the lower the incurred losses. (Hint for those wondering: Wire gauge size is sort of counter intuitive for most folks… The lower the gauge number the larger the cross section of the actual conductor wire…. Hence as wire cross section increases the less resistance to current flow)
In our situation in Over Easy we previously mostly ran our old Thermonic fridge on shore power as the unit had pretty good insulation. When using it on road trips I found that the unit drew enough current to occasionally pop the fuse for the rearmost DC outlet while if we used the DC outlet up front this wasn’t an issue.
I’m very much considering adding dedicated heavier wires for both the vans and the boat with a dedicated circuit breaker outside the existing wiring bundles. That way I can route all the wiring more directly for shorter lengths and pre-emptively avoid any wire heating issues. My only concern is in where to mount the switch/circuit breakers where they are closest to the battery but still readily accessible.
I really am appreciative of all the suggestions and help recieved on this topic so far.
Thank you!
Best Regards,
Over Easy
