Boatlift support bunk setup
Locked
PeteC
Post by PeteC »
I just got a 2001 26X. I have the good fortune of having a lift to keep it on. I need to set up the support bunks on the lift.
Currently there are 2 longitudinal bunks that are 12 long between the 2 crossbars. I am assuming that flat longitudinal bunks wont work because of the Macs curved bottom.
Should I make supports that match the trailer supports?
Should I add additional supports?
Is there another arrangement that would work for the Mac?
All suggestions are appreciated.
Oh, and thanks for a great forum. It helped me make the decision to get the Mac 26X
PeteC
PeteC
Post by PeteC »
I called MacGregor. I told them what I was doing. They didn't offer any suggestions other than to match the trailer. They didn't have drawings of the trailer setup so I will measure it myself.
Maybe I talked to the wrong person there.
How "exact" do you think I need to match the trailer supports? Has anyone built or added supports to a non-Macgregor trailer? Any issues?
Thanks.
PeteC
Post by Frank C »
PeteC wrote: ... How "exact" do you think I need to match the trailer supports? Has anyone built or added supports to a non-Macgregor trailer? Any issues? ...
You're one of maybe two I've read of that has a boat lift ... you're a lucky guy! The downside is that you'll probably find very little advice on the topic. IMO, exact isn't so important. If I was in your spot, I'd try to add a 4th bunk closer to the transom - the trailer does not extend that far back, but I've always been uncomfortable with that big outboard as a lever on the last trailer bunk.
Bill Ernst
Boat Lift
Post by Bill Ernst »
I kept my 97 26X (Wobegon) on a lift for two years. I basically matched the bunks on the trailer, I used 2 x 8's and wrapped them in some indoor outdoor carpet for padding. I think they were 10 or 12 ft. long. The lift held the boat very nicely and it even road out quite a storm on the Lake Mille Lacs here in northern Minnesota one time. The wind got up over 60 mph and in the middle of the night. I woke up and went down to the dock to make sure I had it cranked as high as possible and then just waited. What a helpless feeling. The waves eventually built higher and higher and finally ended moving the Mac and the lift downwind about 6 feet away from the dock, and also destroyed the dock. The boat was OK and that was the important result. Next year I put the lift in a harbor on a different Lake and had no problems. Also in the harbor I didn't feel the need to crank it up very far and the bottom sure stays NICE 8)
PeteC
Post by PeteC »
Frank C:
I was planning to add a couple extra supports where the lift frame is. I hadn't thought about adding one near the transom, but that is a good idea.
Bill:
The previous owner had a large (11,000 lb) boat on this lift that survived hurricane Isabel last Sept. I may need to add the water ballast if another hurricane comes.
PeteC
Dimitri-2000X-Tampa
Post by Dimitri-2000X-Tampa »
I'm thinking about a lift myself, getting tired of scraping barnacles out of the CB trunk!
I'll bet if you put a couple long longitudinal supports (front to back) like you see with most powerboats, it would give the hull even more support than the three latitudinal trailer points.
PeteC
Post by PeteC »
I don't know that straight longitudinal bunks will work. The bottom of the Mac is curved.
I copied the Mac trailer bunks. I added another bunk as well. Maybe someday I will make some drawings to add to the Mods page.
I have lifted the boat with full ballast to check for leaks. I didn't notice any hull stress problems. The holes for the speed/depth finder were leaking.
I will fill the ballast if a hurricane is going to hit.
PeteC
Post by PeteC »
I see Tony posted a mod that showed some pictures of his trailer.
<http://macgregorsailors.com/cgi-bin/mod ... record=435>
You can see that the bunks flex somewhat to match the bottom contour. If I had seen these pictures I might have done my lift bunks longitudinally, as it would have been easier to build. I like the way the bunks support the back of the boat better than the Mac trailer (and my lift).
So far though I have had no problems with my lift bunks.
Thanks Tony!
Locked
