So here's the ticket: order a 3-bow, 6' long, 79"-84" wide, 30"-36" high Hurricane Bimini Top from Overtons.com [item # 29793 if you want it in Sunbrella] and a set of the MacGregor genoa track bimini mounts from Bill or your favorite Mac dealer. I know the tracks on the Mac are only 72" apart -- but it will fit! And the wider the top, the more shade you get.
When folded back with its cover zipped on, it will rest right on top of the aft stanchions [put rubber caps on top of them] and snugly inside the lifelines [ours have vinyl covers] -- no interference with opening the helm seat, or boarding from the ladder, or dropping the mast onto the arch -- and no extra support poles needed. When up, it can be positioned anywhere along the length of the genoa track, depending on the angle of the sun. Even fully forward it doesn't conflict with the mainsheet. And it's the perfect height for a fixed-height bimini -- doesn't interfere with the boom on any point of sail, yet it is possible [for me, at 5'11"] to stand under it with only a bit of a slouch.
Again, this is not the top for you if you have an
[on edit - for some reason when I first posted this, I was thinking that the pedestal-mounted mast support on the '03-04 M would pose a problem - obviously it wouldn't.... this bimini should work on any 26M]
