Mark Prouty
Posts: 1723 Joined: Mon Jan 19, 2004 8:52 am
Post
by Mark Prouty » Sat Jun 24, 2006 2:06 pm
I have a leek at the rub-rail. Does the Mac ever heel enough to bury the rub-rail?
Scott
Posts: 1654 Joined: Tue May 18, 2004 12:46 pm
Post
by Scott » Sat Jun 24, 2006 3:34 pm
I neglected to hang over the gunwale to check but Im pretty sure I've had mine wet a time or two. (It didnt leak) Is a Leek a fruit??
Mark Prouty
Post
by Mark Prouty » Sat Jun 24, 2006 4:54 pm
I'm speculating that with the high freeboard it would have to be almost flat over to bury the rub-rail.
Leek - An edible plant (Allium porrum) related to the onion and having a white, slender bulb and flat, dark-green leaves.
Scott
Post
by Scott » Sat Jun 24, 2006 6:43 pm
That would be affirmative. We have had to spill wind while propped against the inside of the coaming a time or 4.
Ive never dragged a main on a Mac and have on keel boats with less freeboard, but I have dragged my spinnaker a few times.
Night Sailor
Posts: 1007 Joined: Mon Dec 26, 2005 4:56 pm
Post
by Night Sailor » Sat Jun 24, 2006 8:24 pm
If you are paying attention, you should never have to bury the lee rail on a Mac, but it might be fun to deliberately try it. Otherwise, how will you know first hand how the boat handles in such conditions should they come up unexpectedly because you were not paying attention?I suspect it would be rather hard to do on an X or M. Both are forgiving boats under normal rigging and handling conditions. I used to put the rail in the water frequently on my old V222.
zuma hans 1
Posts: 129 Joined: Sun Jan 15, 2006 12:29 pm
Post
by zuma hans 1 » Sat Jun 24, 2006 9:19 pm
Had the leerail wet twice, both on Lake Mead, neither exactly planned. No leaks except I had to change my shorts after we rounded.
James V
Posts: 1705 Joined: Sat Jan 22, 2005 9:33 am
Post
by James V » Sun Jun 25, 2006 2:15 am
I do not bury it when sailing. When motoring, the rear 1/2 gets wet on the underside and sometimes it gets wet on the top with spray.
Where is your leak???
Mark Prouty
Post
by Mark Prouty » Sun Jun 25, 2006 6:19 am
I'm a little embarrased to mention it but I side swiped a tree in my yard. You can't even see the damage unless you look closely. My son and I were speculating whether we sould sail with the boat that way but decided the damage was too close to the chainplate. $1,500 damage. Getting it fixed this week.
Pulling the boat around can be more dangerous than sailing.
James V
Post
by James V » Sun Jun 25, 2006 11:57 pm
Well, I ripped mine about 2 inches comming into a dock. Plan on putting some 4200 on it and see if I make any more before I replace.
Here's to learning.
RandyMoon
Posts: 779 Joined: Mon Sep 13, 2004 7:05 pm
Location: Rockwall, TX Lake Ray Hubbard 2005M #0690 L405 Tohatsu TLDI 90 (Rhapsody in Blue)
Post
by RandyMoon » Mon Jun 26, 2006 3:51 pm
I think trees have the right of way. Was it windward or leeward?
Mark Prouty
Post
by Mark Prouty » Mon Jun 26, 2006 4:00 pm
Trees do have the right of way. I just wish they could be more malleable.
baldbaby2000
Posts: 1382 Joined: Sun Mar 28, 2004 8:41 am
Post
by baldbaby2000 » Mon Jun 26, 2006 7:50 pm
I've buried the rub rail more than once but not intentionally. The winds are pretty gusty where I sail.
