Trailering
Lease
Post by Lease »
Just a small point of correction in regard to tonne, and ton. A tonne is 2,000 kgs. A kilogram is roughly 2.2 lbs. So a tonne is around 2,200 lbs. Given that a ton is 2,220 lbs, a tonne is as near as anything to a ton.
Not that I want to be a crusader for metrics. We had to go through it in the seventies and it's better to look forward than backward.
When I was a kid growing up, we still had pounds shillings and pence. Land area was measured in perches, fuel consumption in miles per gallon, and at the horse races, they passed furlong posts on the way to the finish.
It's a bloody long process to convert, but you have to start sooner, or later.
Craig LaForce
Post by Craig LaForce »
just noting a typo, should be 1000 kg for a metric ton.
Bill at BOATS 4 SAIL
Sailboat: MacGregor 26D
1,000 kg = 1 metric ton = 1 long ton
2,000 lb = 1 short ton
rockman
Post by rockman »
Metrics - the only thing the French can be proud of.
You cannot even settle on gallons (are they US or British).
How come French cars still come with 14" wheels?
"How many French soldiers does it take to defend Paris"?
Nobody knows - they have never done it.
Just quoting the Random House Webster's Unabridged Dictionary
metric ton
"a unit of 1000kilograms, equivalent to 2204.62 avoirdupois pounds. Also called tonne. [1920-25]"
ton
"a unit of weight, equivalent to 2000 pounds (0.907 metric ton) avoirdupois (short tun) in the U.S. and 2240 pounds (1.016 metric tons) avoirdupois (long ton) in Great Britain."
There isnt an ounce of useful information in this thread, other than a wanTON disregard for units of measure...
You deserve some sort of punishment for that :P
What kind of punishment will your meter out?
Are you coming after my relatives?? Kill Gramma??
(Ooohh,,,that was a horrible one)
Lease
Post by Lease »
Surely that should be metre out.
<runs>
Mork
Location: Dorset Southern England UK 2000 X "CORVARA" 50hp Yamaha 4 stroke NaNu NaNu
Post by Mork »
Now thats a barrel of laughs
