lines on boom for new Mac 26X owner
- Captain Wm Hook
Ahoy....Just purchased a 26X for wife's B-day. We sailed her once w/ old owmer for 30 min. We are setting her up today for maiden solo sail tomorrow.
Here's the rub.... We have lines on the back of the boom that seem to loop around and go to grommets in the leech of the main 1 & two battens up...what's the use of these? where do they go????
The outhaul has been identified.
There is also a block & tackle system that goes to the bottom of the mast from the boom and connectes into a 1/2 ring on the bottom of the mast. and one "free" block on the same 1/2 ring...what goes there??
- March
The second question--that's the boom vang. You can use the blocks to make sure that the boom is pulled downward and the main sail doesn't balloon excessively. I am not really good at finetuning it--usually I keep it as tight as possible. I would be interested in some pointers, too. How much of a difference does it make?
For the first question--sounds like the factory reefing points?
- Captain Wm Hook
I think the lines you are describing are your outhaul - you tie it off on the port side of the boom on an eye, then through the leech grommet, then cleat it on the starboard side to adjust the tension of the foot. A real simple upgrade is to put a small block on the eye and gain a 2:1 advantage in tensioning power on the outhaul....... We have lines on the back of the boom that seem to loop around and go to grommets in the leech of the main 1 & two battens up...what's the use of these? where do they go????
Welcome aboard, Captain and Admiral!!
- Captain Wm Hook
I have the outhaul located and it has a pulley system for 2:1.......I know where the boom vang is AND figured out that the block on the same "D" shaped harness is for the halyard.
What still has me puzzles is this?
There are two MORE pulleys bolted to the mast. through these, run a loop of line up through two SS grommets.......
.....I think I just hit on it gentlemen, It's the rear of the reefing system
THANK-YOU and I'll post tomorrow how the maiden/solo sail went, (HOPEFULLY
Harvey
This morning I read through the new msgs, including those from/to Cpt. Hook and his new X. This afternoon I stopped at the Detroit Lake launch ramp and saw a shiny X at the dock. Since in two years I have seen only one other M or X on the water, I quickly parked and went down to appreciate the wondrous vessel. It turned out to be none other than Cpt. Hook, to my surprise.
He sure found a nice X. Very clean, almost no signs of wear for a 7-8 year old boat. It has all the nice-to-have additions one could want, stuff that will take me years to set up on my X. And the best part is that Cpt. Hook and wife impressed me with what very nice people they are to share our interest in Mac sailing with
Welcome aboard, Adm. and Cpt. Hook.
Harvey
Harvey
- Captain Wm Hook
Detriot Lake, OR Sunday
Thanks again, Harvey! I really appreciate your advice and pleasant humor! Hope to see you again....maybe in the water. That would be TOO cool to see you and your admiral & pup on the Puget Sound this summer. PM me when you are taking your Mac North.
Hook
Yes, I am a pir8, 200 yrs too late
