While sailing with the jib, I have problems with the jib sheet wrapping over itself on the winch. I believe this happens mainly while sheeting in with a few wraps on the winch.
This is probably an old subject, I did attempt to search for old posts but have decide to take the easy way out.
Do others have this problem, I am trying to figure out if it is an equipment problem or an issue with my technique. The winches are stock 2003 stuff. I usually wind the sheet clockwise around the winch a few times, then either sheet it in or ease it, and pull it into the jam cleat. This over run problem is killing me.
could I get some advice?
thanks,
Kevin
Winch Overwrapping?
- Ivan Awfulitch
Welcome aboard ~ your 2003 26X is a rare duck!
Overwraps are common, and potentially dangerous. You need to understand and recognize the causes, and be careful in your line handling. The main issues:
Roger should add 5 bucks to the price and do this at the factory.
- The first wrap is at winch-bottom and subsequent wraps climb higher;
- You must try to always hold your line tail above the last wrap, the highest one;
- If the cam cleat is too low, it can contribute to overwrapping as you try to adjust trim;
- You can minimize this tendency by using only one wrap on the winch.
Same here
I also used the riser blocks, like Moe's mod. I don't know the model number but I believe I used Ronstan risers that I got off the rack at West Marine - they might be 1.25" vice 1". Either way, they make all the difference.
This was probably the first mod I made to the boat.
- Andy
- Andy
