Boat hook
Craig LaForce
Just another way for you to consider.
On my X I removed the black plastic winch bolt onspection cover plate after inadvertantly breaking it in half. Even though I had previously installed the boat hook holder clips just aft of the head door hinge, I now simply hang the boat hook from the hole under the portside winch. It is super easy to access from the cockpit and it never falls out.
Cost = nothing.
Cost = nothing.
LOUIS B HOLUB
A Boat Hook in my Opinion is one of the essentials on my MacX. Stuff overboard, hooking to a pier, line grab, retrieving, etc.johnnyonspot wrote:I do not have a boathook. I have done alright without it seems, do I really need one?
Ive had a few encounters coming into the slip when the boathook saved a few scratches too.
Theyre a great invention.
edit add: Im amazed at the number of us Mac X folks that store the boat hook at the same site: attached to the cabin wall, aft of the head door.
It definately must be the best place.
- tangentair
Not putting down the boat hook which usually is esential to pick up the PFD that "fell over the side" but you can grap a mooring ball with a loop of line tossed over it in high seas a lot quicker, tie one end with a bowline or similar knot and cleat the other end off. Then when things die down, untie or cut the line free.
on edit - oh yeah, ours lays loose in the aft under cockpit jumble till its needed and usually till well after its needed.
- parrothead
Our telescoping boathook hangs from clear, soft suction-cup "tool holders" that we got from Linens 'n Things http://www.lnt.com/product/index.jsp?pr ... age=search nearly 3 years ago - and they have never fallen off the liner [even though we trailered during our first season]. You can see the hook end in the upper-right corner of this photo
--- readily at hand from the cockpit, but not in the way of anything.
--- readily at hand from the cockpit, but not in the way of anything.- greybird-M
- Location: Cocoa, Florida, Aquanaut, 03 26M, 50 HP Honda
- Beam's Reach
- Location: North Bay, Ontario, Canada 97X, 50HP Mariner 4 Stroke
- pokerrick1
- Sailboat: Venture 23
Boat Hook
My dock lines are permanently set so the boat is always in the same place where I want it - - - so I use the boat hook mostly to retreive the lines and bring them onto the boat for connection to the cleats. The telescoping boat hook was the FIRST piece of equipment I added to my Mac.
Rick
Rick
- tangentair
boat hook etc
2 boat hooks, whisker pole, man overboard flag pole et al store horizontally on portside hull liner wall. Aft end portions are received in 3 short lengths of 4 inch thin wall plastic pipe, bolted together in a triangular array. The array is hung up snug in the waste space between the hull and the back of the cockpit seat. The front portions of the poles are loosely and removably supported in rope loops of different lengths. The loops upper ends are knots trapped between the lower edge of the upper cabin liner and the upper portion of the hull liner. The loops are spaced a few inches aft of the galley. Bend the loop forward a bit to release the front of the pole and pull the pole forward out of its plastic pipe and the pole is free to use. Cheap easy and no holes drilled in the boat. Ron
- Morimaro
Boathooks - use of
My old sailing instructor always told us it is a boathook and if you hook and pull it won't slip, if you push using the hook it could easily slip. But if you really need to push, then push with the handle end forward not the hook.
Morris
Morris
