IDA RUDDERS
Bawgy
IDA RUDDERS
Post by Bawgy »
Just got my new rudders from Ida sailor . A tree fell on one of the old ones and gashed it up pretty bad so I ordered a new set . Hope they live up the good reviews I read about here.
baldbaby2000
Post by baldbaby2000 »
Bawgy,
Let us know what you think. In my opinion they help mainly in very light air and heavy air. It's hard to do an objective comparison because the Admiral and I have gotten better at controlling the boat over time so it's have to completely credit the rudders but I'm glad I have them.
Daniel
eric3a
Post by eric3a »
I got them for my mac19 she now responds so fast its unbeleivable
Cheers John
Bawgy
Post by Bawgy »
Put the new rudders on this weekend . Will try them out at CLO this weekend . Pretty easy fix. all the holes were in my rudders but the travel lock holes didnt line up . The Rudder would hit the transom before the hole was fully exposed . About ½ the hole showed through the mount when the rudder was raised . I drilled two new holes instead of enlarging the old ones . I did not want the rudders to bounce up and hit the boat when towing
baldbaby2000
I had the same issue. I think I elongated the holes.
Daniel
atzserv
ida sailor rudders
Post by atzserv »
I called idasailor when i discovered the holes didn't quite match, they said drilling them out to fit was ok and didn't cause any integrity issues and that they would look into it, They seemed to think the newer Mac used the same size bolts as the actual bolt that mounts the rudders and that the older ones were just smaller.
gary
Bawgy
Post by Bawgy »
My biggest complaint was the alignment of the holes not the size . I would like to have been able to raise the rudders higher to trailer but had to drop them down enough to space new holes away from factory ones
Post by K9Kampers »
I'm not in the market for M rudders, but I've noticed this on the Kelly-Hanson Marine website:
Ida Sailor performance M rudders $699 / pair
Factory manufactured M rudder $95 each
I know it's apples v. oranges, but huh?....
Bawgy
Post by Bawgy »
I didnot pay that much but they are very good rudders. I like the material and they do perform better. I busted mine so I replaced with the beefier rudder . I would not just replace to enhance performance because then where would it stop . Carbon Mast and Boom Detachable remote controlled dinghy with out board to follow around when racing. Carbon Sails . The list would go on
Yes the rudders are better but if you are ok with the Stocks Wait until you need one .
dancing_bear
Post by dancing_bear »
About 6 months ago Idasailor rudders doubled in price, supposedly due to the cost of raw materials. I scored one for my Mac25 for about $260, a week later the price was about double.
The Mac25 idasailor rudder was not drilled at all.
delevi
Post by delevi »
They never put the holes in the right place. Better to get them undrilled and drill your own holes.
Leon
Highlander and I got a set each. I had no issues with the holes at all. Just took off the stock ones, attached the IDA set, good to go.
Have been sailing 6 out of the last 7 days, was in a sailing race, logged several hours now.... love them! Much better at keeping my M on her feet. Tries to round up in a puff, with quicker response and more surface area, the IDA set hold her hard against the temptation to round up.
Best money spent on my M to date.
Post by K9Kampers »
My IDA rudders were just delivered today!! Still not any closer to going splash tho. The Fed Ex delivery guy turned out to be a Mac X owner that I met two years ago when launching mine...small world.
K9Kampers wrote:I'm not in the market for M rudders, but I've noticed this on the Kelly-Hanson Marine website:
But you got them today !!!
k9Kampers then you should have got them in early Feb. before the price went up Beene & I paid less then $400./pair saved $300. each !!
