Re: A New Journey Begins for OverEasy - 2023/2024
Posted: Sun Mar 31, 2024 12:18 am
Hi All!
The spirit of Abbot & Costello are alive and well in my boat prep projects
Well Iāve gotten the edge taping done and the keel dropped for the anti fouling painting ⦠except there are barnacles lining both sides of the trunk that werenāt visible when the keel was in place.
Another last minute project to be accomplished⦠I got an angle adapter for my pressure washer along with a long handle wire brush⦠unfortunately the barnacle foot crud does not just scrape off. Iām gonna have to allow another day after the pressure washing to allow the hull to dry out before actually painting it⦠Fribble⦠so much for an optimistic scheduleā¦
š«¤
The keel pivot, now that itās removed, shows measurable corrosion pitting of the frame and pin⦠fortunately I already have a new replacement frame and pin on hand from BWY. I just need to modify it with a longer lift bolt (which makes it more manageable to install/deinstall by myself). Yet another last minute projectā¦
The keel was apparently repaired sometime in the past by one of the previous owners who only used a big chunk of resin instead of actual fiberglass
. While that worked (give credit where credit is due) to a certain extent it gave up the ghost and fell apart at some point over the past season. So now itās time to clean out the old repair attempt and get it done right with actual fiberglass⦠Another last minute project in addition to painting it with epoxy primer & anti fouling paint.
No way we are going in the water by the first of April at this point. More likely mid April or later at this rate not counting potential weather issues that may arise⦠Fribble.
Such are the plans of mice and menā¦
One day at a timeā¦..
Best Regards
Over Easy
Best Regards
Over Easy
