Posted: Thu Jul 08, 2004 4:06 am
With my ablative bottom paint (rather rough and not slippery at all) the bump never worked for me. And I've tried tightening the winch on the way up the ramp and all it did was flex the winch support after a certain amount of tension was applied.
This spring in the backyard I finally got the hull to move forward for the first time. I adjusted the trailer jack down, put blocks under the boat's stern, then jacked up the tailer jack removing the rear of the boat from the trailer, then cranked the winch and tried rocking the boat by pusing hard on the sides. Worked pretty well. Not perfect, still about an inch back but much better than 3 or 4 inches back.
I don't use ramps very often so have not practiced much. Maybe the soap idea would make it better. Neer tried it.
