Hatch latch
Kilblaan
Location: Sackville, New Brunswick, Canada - 2001 26X, Honda 50hp
Re: Hatch latch
Post by Kilblaan »
The original hatch latch/screw is still working fine, but as others have reported you end up on your back unscrewing it :(
Here is a picture of the sliding mechanism on the inside of the hatch http://picasaweb.google.com/Kilblaan/Ma ... directlink ... if it was a SS rod instead of a spring it would make more sense as you could then adjust the amount the hatch is opened ... does anyone know perhaps where a SS rod with holes in each could be purchased?
tangentair
Re: Hatch latch
Post by tangentair »
Kilblaan wrote:I'm a new owner of a 2001X ... I've been able to find solutions for all my other queries thru the search and advanced search. .......What is the purpose of this spring and slider?
Sounds like a previous owners attempt to accomplish what your trying to do.
Kilblaan wrote:As a related question is there any trick to get a screw to work once the hole is too large vs putting in a larger screw?
It is a lot more work than a larger screw but you can drill out the hole, mix up some epoxy, sand and taper the sides so it will grip and fill everything back up, then drill and use the original size screw.
Ron
 ! kmclemore:
Fixed your quote. -kbm
Kilblaan
Re: Hatch latch
Post by Kilblaan »
After more poking around and taking srews out and peaking in behind it seems the PO spread some sort of adhesive on the inside of the hole (assume waited till it dried and then put the screw back in) ... would this be one of the 3M adhesives :?:
Back on the forward hatch ... seem when the spring is compressed its rigid enough to keep the hatch open ... still unsure yet of the whole design philosophy :?
Ivan Awfulitch
Re: Hatch latch
Post by Ivan Awfulitch »
I've been using one of these for 2 years and have had no problems. Holds the hatch open slightly more than straight up.
http://www.westmarine.com/webapp/wcs/st ... assNum=487
Captain Steve
Re: Hatch latch
Post by Captain Steve »
Same one as Ivan for 4 years.... and it still holds at a variety of angles
