Anchor Locker modification
SkiDeep2001
Re: Anchor Locker modification
Post by SkiDeep2001 »
Just remember that 3 of 4 NFL ers died in the Gulf a few weeks ago trying to dislodge a stuck anchor. If it's really not coming loose after a good effort,give it up and cut the line and buy a new one. :cry:
BigNige
Post by BigNige »
Hi,
Bizzy wrote
"I will run a drain from the chain locker box to the recessed box at the ballast plug. The relatively small amount of water from pulling the anchor can then be drained when I empty the ballast."
I hardly ever use my anchor so the locker stays locked for months. Last month whilst cleaning the topsides I took out the anchor and there was a lot of dirt around the drain hole which means that a lot of rainwater is getting in. I wouldn't compromise the water tightness of the boat by installing a drain from here to the dam around the ballast tank plug. A connection into the sink/motor well drain would be safer.
Rgds
