Is this mod structurally safe
Re: Is this mod structurally safe
I've been considering doing the same mod for awhile. What sort of container did you use on the inside? The one's at the marine suppliers are pretty expensive.
- Indulgence
I just threw in a blue plastic bin from Canadian Tire I got for ten bucks.
Probably get the same thing from China-Mart.
It's not elegant but will keep everything in place below the hatch. I expect
there will be some pros and cons when I use this. Might need some tweaking
along the way.
L
along the way.
L
- DaveB
As a FL. Lic. Structual Building Inspector and FL. Lic. Building Contractor along with many rebuild boat projects with all kinds of Fiberglassing and Epoxy expearance.
I would say the deck is of one unit as a whole for structual strength. Some areas you can put in a small hatch like under the cocpit horizontal face.
Cutting into the top and edge as you suggested will effect structual strength.
The Mac. hull and deck flexes and cutting out a section you decribed will weaken the hull and deck as a unit and will probably see stress cracks appear if sailing hard and in sloppy seas and could lead to strucual failures.
I know a few have done this and hope they never get into a heavy Sea to find out.
Just my personnal and Professional opion.
Indulgence wrote:I'm going to follow in the footsteps of others and make the space below the starboard seat into a storage locker.
I don't want a side access hatch with a box behind it. I was thinking of a top opening hinged door with a large
vertical storage container all the way to the deck below.
Forgive the lousy picture, but the idea was to illustrate a cutout in the seat that
flows over the edge onto the vertical to provide a solid front lip for support.
There'd be a piano hinge across the back and flanges below with weather stripping.
I'm leaning toward reinforcing that front lip with angle alumininiminium or flat bar.
The question is: in your opinion, could this compromise the structure of the boat?
Thank you,
Laurie
