Re: Rudder Lifting & Hold-Down Lines
Posted: Wed Oct 28, 2009 7:04 am
When using the bungee hold-down rudder lines mod, I recommend you get a few stainless steel "hog rings" which are clips that you crimp around the bungees like cable clamps, to fasten a loop in the end that goes thru the rudder at the bottom. Knots in the bungee cord do not hold very well, and make a large blob on the side of the rudder. There is not alot of distance clearance between the rudder and fairlead on the transom, so there is no room for a shackle and you have to put a fastener or knot anyway, so I do recommend the hog rings. Just pass the bungee cord end thru the rudder hole, and then back along the bungee, place two hog rings per rudder. West Marine will show you how this looks if you have not seen them, but actually most made up bungee cords with hooks on the ends are factory made with hog rings inside the wound ends of the hooks, so you can check them out that way.
The bungee tension can be stretched a bit to provide complete hold-down pressure on the rudders for any sailing purposes, but allow mud, rocks, logs, etc. to kick them up. Sailing control will be restored as soon as is possible, as opposed to a cleat that completely releases the rudder. If you clear the mud or sand bar, or whatever kicks the rudders up, and are then sailing clear again, but your rudders are not reset, you are likely to break them, and steering forces are going to be hard to control. IF motoring slow, you have to be careful not to allow the rudders get afoul of the prop when they are dangling backwards and swinging wide.
