front mast stay pin
Nautek
Re: front mast stay pin
Post by Nautek »
I replaced mine with a stainless steel bolt that i cut the thread off and drilled to take a stainless steel "R" pin from whitworths
I use this method for all pins except where the baby stays attach to the mast
Allan
verena
Post by verena »
We use a bolt with a nylon locking nut.
trip01
Post by trip01 »
Allan,
I found these...
This one would support a captive cable. :idea:
http://www.whitworths.com.au/main_itemd ... lutePage=1
or..
http://www.whitworths.com.au/main_itemd ... lutePage=2
Kind Rgds
08 26M
Nautek
Post by Nautek »
Hi Dave
I used the retaining clip just because I had some however the humpback retaining clip looks good too
The chances of the retaining clip coming out is remote whereas the humpback might under some applications
Horses for courses
Just carry some spares
Allan
mike uk
Post by mike uk »
What? Carry a spare mast?
(Only joking) :)
Mike
Nautek
Post by Nautek »
Mike
If you had a blue boat with the fancy mast you might have to :evil:
Allan
Nope the M mast is bigger & stronger & longer. the X mast at 28ft is stretching the limits of that mast. the :mac19: has the same mast as the :macx: only the :mac19: mast is 24ft two sectional I extended the mast on my :mac19: to 28ft & made it a three sectional mast with a second set of upper spreaders & upper jumper struts it has two forestays & four sets of shrouds supporting it ten times more support than the regular :macx: mast at the same height :!: :idea:
Now go listen to me ya'd think I was from TX or something :D :D :D :D
J :P :wink:
