CQ CQ CQ de KD4LZL
Currie
Re: CQ CQ CQ de KD4LZL
Post by Currie »
Kelly Hanson East wrote:.-- .... .. - . / .... ..- .-.. .-.. ... / .-. ..- .-.. .
Talking smack just doesn't have quite the same impact when it has to be deciphered - "let's see that's 'w - h - ".....;)
Currie
Post by Currie »
! If you guys don't settle down, we'll be moving this thread to the 40-meter novice band!!!
Post by Kelly Hanson East »
Can I 'dis a Moderator in Morse code??
ANS: Only if you show Re-Morse, of course.....
Hamin' X
Post by Hamin' X »
And if you do, we'll cut you up into bite-sized Morse-als. :wink:
heh heh...
HERNDON
Post by HERNDON »
Rob WB6COT Clovis,CA. & Dianne N6YGC.... Wife on 800Mhz (cell) now
Use HF/VHF and UHF... Headphones on when I am reading this site...
Yaesu FT-897 using Ham Radio Deluxe for software control.
HF receiver boatanchors. This is my post for 2010......hi hi....
Wonder if that is suppose to be in caps when not sent in CW...
Rob
Doctor Z
Post by Doctor Z »
VE7 CCZ here in Vancouver - not much HF these days - a little 2 meters
Craig
Hamin' X
Post by Hamin' X »
I need to make a complete list of Hams on the board. Perhaps we can run a contest? WAM! Worked All Macs award. Multipliers for multiple bands and modes. What a hoot! I like the idea of working field day from the Mac. I've messed with backstay and verticals on other boats, and loaded dipoles on my old V-17, but none were really satisfactory. I'm thinking of running a wire from the bottom of the compression post to through the bilge and up the transom on the inside. from that point, I will load it with my auto-tuner between the wire and the backstay. Should make a nifty loop antenna and require no ground. Might work great down to 40M and fair on 75/80M. Best part is, I can test it with the boat on the trailer. I'll let you know how it works out.
hartflat
Location: Keene, CA "Isabel II"- '08 MacGregor 26M, E-Tec 50
Post by hartflat »
KI6FXU up in the Tehachapi mtns., east of Bakersfield, CA
mostly local 2m & Echolink.
73's
carriacou
Location: Everett WA-- "Carriacou"------ 99X-- Nissan 50D
Post by carriacou »
N9OHG up here in Everett WA.
Lost all the HF gear in a fire in the moving van that moved us here from WI.
Still play on 2M as that was in the car we drove out in.
don
kleinhhl
Post by kleinhhl »
W5TAF here in Tulsa, OK.
2000 Max26X on Oologah Lake.
Mostly operate HF CW but enjoy all aspects of the hobby.
I will be at the Dayton Hamvention in May. 73 de W5TAF (Hugo)
Capt Sully
Post by Capt Sully »
kleinhhl wrote:W5TAF here in Tulsa, OK.
Sounds good. Dayton is a place every ham needs to go at least once. :macm:
Luke
Location: Boardman, Ohio, DreamChaser, 1999 26X, Honda 50HP
Post by Luke »
I will be checking in with the Maritime Mobile Service Network while I sail from Isla de Mujeres, Mexico through the Dry Tortugas on the way to Key West next week. If anyone would like to make contact with me, the net is on 14.300 MHz, on the hour, from noon through 9:00pm EST. The boat's name is "Joli Spot".
Luke
KD8FWS
Capt Sully
Theres got to be some D-Star users out there? Give me a call on KI4SBA 145.200 on the Georgia 30C repeater location. Find it on dstarusers.com :macm:
73 KD4LZL
