Air Conditioner - other ideas?
DaveB
Re: Air Conditioner - other ideas?
Post by DaveB »
Defenders has a sale on built ins, you will need a thru hull for water intake. Cost you around $1350 with everything.
Or you can do what I do.
$90 for 5050 BTU AC, $22 for 1/4 white Plexiglass and $3 for redwood support.
Here are some pictures.
http://s182.photobucket.com/albums/x25/ ... itionMacX/
jschrade wrote:I have seen the modifications for mounting the air conditioner in the companionway via a cut-out board but that is likely beyond my skills and a little too hard to stow.
My thought is to essentially sit the air conditioner right on top of the traveler heading into the cabin. Obviously providing a platform for it to sit on. Then just create a cut-out (in multiple pieces) to fill where the cabin slide in door would normally be. It would seem that this would be the simplest way to set this up and my intent if to try and find an A/C that would fit in one of the cockpit wells. with the door pieces. Has anyone gone down this path? This thought came when I was looking at some modifications where the cabin door was cut into pieces to make it easier to stow.
I'd love one of the carry on type A/C's but at $999 that is not going to happen.
Jim :macm:
Craig LaForce
Post by Craig LaForce »
Dave, can you give us any info on that Edgewood fridge? Price, where to obtain, how it works? Thanks
DaveB
Post by DaveB »
A few of us has bought this unit in past 3-4 mo. and detail info is in the archives. Do a search on DaveB or Edgestar and you will get the info.
Craig LaForce wrote:Dave, can you give us any info on that Edgewood fridge? Price, where to obtain, how it works? Thanks
pokerrick1
Sailboat: Venture 23
Post by pokerrick1 »
Be sure to check out Craig's List - - Boats for sale. Here's an ad with a deal today in Las Vegas CL - - there are pictures in the ad:
New Portable Boat Air Conditioner - $600 (Las Vegas)
Date: 2010-05-23, 2:15PM PDT
Reply to: see below
Brand new never used bought it from WEST MARINE for $1,000. bucks asking $600 Firm. Is the specs for it from the west marine website. thanks please email [email protected] or text 702-439-6228
Specs;
compressor that produces 6,720 BTUs of cool, dry air. Fast and easy to install by placing the unit in any 12" x 12" or larger hatch and adjusting the fabric hood to seal the opening. Temperature and fan speed are controlled from inside the boat. Draws just 6.9A (running)@115V AC. Weighs 68lb. Optional Air Deflector deflects the normally vertical cool-air discharge to horizontal for better distribution in your boat. One-year warranty.
Reverse Cycle: No
BTU: 6,720
Draw: Running - 6.9A @ 115V AC; Starting - 21A
Controls: On underside
Dimensions: 30 1/2"L x 16"W x 14 5/8" height above deck
Discharge: Single
Cutout Size: Between 12" x 12" and 24" x 24" rectangle or 15 1/2" round
Volts: 115V AC/ 60Hz
PostingID: 1755784218
Rick :( :macm: Less
DaveB
Post by DaveB »
Also ck Defenders built in for $695 A/C and Heat. Ck Map price.
http://www.defender.com/productsearchre ... &sort=none
BillOcala
Post by BillOcala »
Thanks for the link to the Mod Tahoe I had been looking for that for a few days :P I am planning on doing a 26S version of this Mod this week, so a quite timely find this was!
Tahoe Jack wrote:Check out my mod http://macgregorsailors.com/modt/index.php?view=693 where I use a common 5k btu Costco-sourced AC mounted in a removable companion way hatch. No special tools or skills required. BTW, I posted a second mod with more pics. It works well and can be slipped off and stored in your garage off-season or cooler weather. I too have a Honda 2000. 8) Tahoe Jack
