Headstays on most Sailboats I have seen and owned is usually 1 size larger than side stays, Mac. thinks it should be one size under.
Totally disagree and when lowers and uppers are stock 5/32 on the side stays so should the forestay or even one size larger 3/16.
Terry wrote:I upgraded my forestay from 4/32 to 5/32 and the turnbuckle from 1/4 to 5/16 as well. I had to increase the forestay to accommodate a Shaefer Snapfurler CF700 so I beefed up the turnbuckle too. It is only an extra 1/32 of an inch which makes it the same size as the four shrouds that are pulling against it which makes it more equal. I cannot understand why the factory would not make the forestay the same strength as the shrouds given there are four big bully shrouds ganging up on the forestay. It is not expensive to do and any rigging shop will do it and it does provide for more peace of mind. I now have a spare forestay which I may have another use for.
