Sealed center valve - water ballast issue
WidespreadSailing
Re: Sealed center valve - water ballast issue
Post by WidespreadSailing »
P.S. My boat stays in the water 98% of the year down in the FL Keys.
Newell
Post by Newell »
No plans, no pics, sorry.
This project was difficult to my standards. Because there is no pilot hole for cutting a larger hole into the transom ballast tank, it was necessary to make a plywood template that I screwed onto the hull where the new screws would go for the new gate valve. This guided the hole saw correctly. There is no room for error. :|
Matt19020
Post by Matt19020 »
If you need to cut it out with a dremmel you could use something like this to reseal the valve:
http://www.boaterbarn.com/images_produc ... 747big.jpg
Hamin' X
Post by Hamin' X »
You could nest a 3" hole saw inside the 4" one and use it as a guide.
Newell
Post by Newell »
Hamin' X wrote:You could nest a 3" hole saw inside the 4" one and use it as a guide.
Yes, if the factory placed the 3" hole equi-distant from the top and bottom of the tank. The factory was always perfect according to Roger? :wink:
Hamin' X
Post by Hamin' X »
Good point. As always, YMMV.
