The vang makes a notable difference in your sail shape? Do you also use a boomkicker?Hamin' X wrote:Perhaps paying attention to sail shape is why I have absolutely no trouble tacking, regardless of wind conditions?![]()
Phil M
Yes.Phil M wrote:The vang makes a notable difference in your sail shape? Do you also use a boomkicker?Hamin' X wrote:Perhaps paying attention to sail shape is why I have absolutely no trouble tacking, regardless of wind conditions?![]()
Phil M
The only time I ever have trouble tacking is in very light winds, although I can also backwind the genny on a tack. By NOT using a boom vang, the sail shape would be slightly baggier under light wind conditions, and be of more assistance than if the vang pulled the sail down tight. In which situation is the vang helpful for you?Hamin' X wrote:Perhaps paying attention to sail shape is why I have absolutely no trouble tacking, regardless of wind conditions?![]()
Hamin' X wrote:In light air, I ease the boomvang, which allows the boom kicker to lift the boom and provide a fuller shape to the mainsail. This provides more power and actually increases weather helm a bit, which tends to force the bow across the wind. In heavier air, I tighten the vang, which flattens the main and reduces heel. I can tighten the backstay also, which bends the main part of the mast forward and flattens the main further.
There are many trick to shaping sail. On an M, which has a traveler, you could move the traveler to windward in light air. This will reduce the downward pull of the mainsheet for a given angle of the boom, allowing the boom to rise more and provide more shape. The converse is true in heavier air. Move the traveler to the lee to get the mainsheet more under the boom and flatten it. Some move the traveler in the opposite fashion, but on a Mac, I find that this over sheets the main and causes the boat to pinch, slowing it down and increasing heel, which increases weather helm.
On the foresail, you can use the jib/genny cars to the same effect, but it is sort of the reverse. More under the sail (forward), tends to bag the foresail and back is flatter. This is because you are using the angle of the forestay to pull against.
All of this is simplified, because it all involves sail twist, which is a real animal to discuss, but if you follow the simple principles and practice (called sailing and having fun), it will become second nature.
Perhaps it is pulling the mainsheet tight with the traveller under the main, that when tightening the vang, I noted very little, if any, effect on the shape of the mainsail. If I were racing anotherHamin' X wrote:
Aha! I do the same thing, which explains why I was getting unexpected weather helm after tacking in light air after I installed the boom kicker. I have to say that the boom kicker really seemed to help keep the mainsail powered.Hamin' X wrote:In light air, I ease the boomvang, which allows the boom kicker to lift the boom and provide a fuller shape to the mainsail. This provides more power and actually increases weather helm a bit, which tends to force the bow across the wind.
I have heard that before. I just wonder how much strain the boom vang takes off the mainsheet control.puggsy wrote:That boom vang is to prevent the boom kicking upwards, and altering the set of the mainsail...also it takes the strain off the mainsheet control...it should not prevent the swing of the boom from side to side...that is the job of a ' boom brake' if fitted.
hope this helps.
Can't be much- it's at a considerable mechanical disadvantage to the sheets. The strain relief function is very much secondary to its raison d'etre; to give control over sail twist and shape.I just wonder how much strain the boom vang takes off the mainsheet control.
Matt and others... I have thought about installing a boom kicker, on myAha! I do the same thing, which explains why I was getting unexpected weather helm after tacking in light air after I installed the boom kicker. I have to say that the boom kicker really seemed to help keep the mainsail powered.
Matt
Hi Chris, I installed the boomkicker last week, so I've sailed with it and without it. It certainly helps keep optimal sail shape in light air, but the primary reason I bought it actually had nothing to do with performance and everything to do with keeping the boom off the deck in port.u12fly wrote:Matt and others... I have thought about installing a boom kicker, on mybut BWY told me they affect the rotation of the mast. So I opted for the simple topping lift. I know that boom kicker makes a special vserion for the
Do you have any issues?
Chris.
