Catigale wrote:Nice toy...I've add my eye on the Sailrite version for a while.
Are you missing the engine cover in photo one?
Thanks! It's a straight stitch only machine, in case you didn't realize. (see below)
The only machine sailrite has that compares is this one:
http://www.sailrite.com/Sailrite-111-He ... ccessories#
Keep in mind that price does not include the motor or stand, much less someone to properly set it up for you (just in case you aren't experienced.)
There are a lot of old machines for less money that will run forever and take common parts you can get almost anywhere secondhand as well.
You should be able to get a turnkey setup for that price and probably some extras.
Mine is a Consew 226R, it is a Japanese clone of a Singer 111w with reverse, there are other clones too, and all the older ones are supposed to be bullet proof. (This head weighs around 50-60 lbs)
If you want to sew sails (zig zag stich), I would recommend getting an older portable Singer, good ones can be had for $250-$400 and they are supposed to run forever. Again parts are local and cheap.
One local shop here has all kinds of old machines, the old man that owns it has been in business 61 years and he reminded me of this fact several times and once more when I asked him if it was good to go and been checked over the final time I went to look at it and test material I brought with me. His reply was not "yes sir". It was simply "Son, I've been in business 61 years."
I mostly got this machine because of a specialized venture I want to start, and I want to try to get good enough with marine vinyl to make some money at it.
The motor cowl was off because the pull start rope came out of the mechanism and I was winding it around the flywheel. I got it that way and was afraid the mechanism was broken, but to my surprise after some tinkering I figured out how to wind it back up, and tie the rope back in, works great now!
I think I did ok for my first time sewing vinyl, and my first real project with this beast machine. My corners aren't real sharp, but I'm proud of myself.
