Ventilation on a 26m, how?
Re: Ventilation on a 26m, how?
robbarnes1965 wrote:Here is a link to a canadian source with measurements. I think you can buy the screens at many sources and marine stores. http://www.dowsar.com/feature.htm
I was wondering where the PO got the bimini, dodger, and bridge for my :macx:. Now I think I know. The units on their web site look exactly like mine, down to very small details in construction.
http://www.dowsar.com/options2.htm
Bobglas wrote:Did that hatch support come stock?
I bought a hatch support arm to keep the mac hatch open at any angle , & the small glass hatch came with its own
PS I also have a full dowsar enclosure
Québec 1
Post by Québec 1 »
Nice set up....to bad the Hull is White :P
Q1
yukonbob
Post by yukonbob »
Mine is from BWY and definitely looks different. So you can rule that one out
Divecoz
Post by Divecoz »
Those Solar Vents are meant for just that Ventilation.. They are not meant for comfort..Mine works well for That Purpose.. Moving Air when the boat is closed up..and Not In Use... :) I too have a couple 12V fans.. They Oscillate... that seems to help as well.
I had been keeping my boat in a slip and have a Cruise Air.. that is just one of many items, around here, that needs to be sold, now that the move to Florida seems to be just beyond the horizon...
Champguy
Post by Champguy »
Highlander wrote:Here's one of my solutions
Screened opening no bugs
nice evening veiw of the stars even when closed
Highlander,
Which hatch did you install? Where did you get it? How much money?
It sure looks like a nice setup, and what I had in mind for my boat.
Aaron
seahouse
Post by seahouse »
I have the same Bugbusters Hatch Insect Screen as Rob, I like it too, it fits well to keep bugs out, and pulls down in a second.
For sleeping I whipped up a screen for the companionway from a piece of 5/16” birch plywood, some aluminum screening, and some copper gimp tacks. Slips down in place of the factory companionway cover, and folds up tight against the sliding hatch for a bug-proof fit. A great DIY project that can be done by anyone with modest skill and limited tools.
Nice and light and stows out of the way flat against the hull in the aft birth.
-Brian. :wink:
Hamin' X
Post by Hamin' X »
And you posted it in the Mac Mods section, Right? Or soon to be?
seahouse
Post by seahouse »
Yeah - I'm a little behind on some of those, Rich. Hopefully by Christmas... :wink:
seahouse
Post by seahouse »
Due to your kicking my butt :D , Rich, (I did this mod over a year ago) this can be seen under the mods section entitled "Companionway Screen".
-Brian. :wink:
Reason: Link added
Hamin' X
Post by Hamin' X »
More of a gentle nudge. Well done, sir!
raycarlson
Post by raycarlson »
I don't get it. A window hatch in a hatch,with two big factory windows only two feet away.?????
Champguy
Post by Champguy »
I like the hatch in a hatch idea. It makes me feel better about cutting holes in my boat. If for some reason I completely screw up the install, I can replace the hatch instead of trying to patch the hole.
yukonbob
Post by yukonbob »
It would be a neat idea to install the opening hatch in the what appears to be a similar hole of one of the two overhead windows instead.
raycarlson wrote:I don't get it. A window hatch in a hatch,with two big factory windows only two feet away.?????
First of all I sleep in the V berth & u r not going to have that big hatch open in 50mp/h winds , I have had that little one open a crack in that kinda weather for ventilation & as it has a metal frame & a locking support arm so it stands up to the forces of strong winds & has a built in bug screen , it also allows lots of light in the v berth when u need it I also have a blind that closes it off for privacy, it is great for ventilation on the cooler & hot raining weather , & u can go to sleep on the coldest nights & still gaze @ the stars open or closed ! , the big hatch is best suited for launching gear & sails onto the foredeck or as an emg. exit & ventilation on the very hot windless nights , the smaller hatch is an all yr weather hatch
Some people have already done the small hatch in the front windows as u mention but I am not so sure thats a good Idea becuase I am not sure that will not eventualy lead to cracked windows because u r now putting a lot of stress on a window when the hatches r open from strong gusts of wind , but I do like the Idea of the front windows opening & may one day do that mod , but I think the ideal mod would be for custom made opening windows to completely replace the original windows but thats going to be big money but if one could find already manufactured windows that could be easily made to fit or needed slight mod to fit would be the best ideal
