Re: Tohatsu 50 mystery
Posted: Fri Jun 29, 2012 12:16 pm
I just got off the phone with 2 dealers.
After the usual items we all guessed at, he said to try unplugging the wiring harness form the power throttle quadrant. I find it hard to believe it is a bad switch because it is so predictable.
Dealer 2 said it could be a spider nest in the carb float vent. It would have to be one carb for all three for that to be the deal. I can't remember if I have 1 carb per cylinder or 1 for all three.
I will try these things and then, if that doesn't work, introducing fuel into the intake externally, at the time of shut off (duct taped very small hose to inlet hooked to a squeeze bottle) If the oil bearing fuel doesn't revive it, it's probably got to be electrical.
I hope a spider cramped my speed. I'd like to clean out a nest and maybe hit the advertised speed number instead of the 10 MPH tops with fins up, ballast and 4 adults on board.
come on spidey
