New Glass2 on Knot Shore
Lvoight
Re: New Glass2 on Knot Shore
Post by Lvoight »
I would also like to know this... Should we do the skid area also with this?
Azzarac
Post by Azzarac »
I use NewGlass2 on just the stripe but I do treat the nonskid area between the portlights. I have noticed no noticeable difference between the treated area and non treated as far as traction goes.
Fair Winds,
Capt. Azzarac
Chameleon
Follow Chameleon's travels at: http://svchameleon.weebly.com/
Lvoight
Post by Lvoight »
Thanks for that, I was worried about creating a ice skating rink. Did you also do the windows? Looks like the Knot Sure did and turned out well.
thanks
Azzarac
Post by Azzarac »
I wasn't sure what the outcome would be if I coated the windows so I masked them off before applying the Newglass2. That's a great question though. I may have to find a scrap of tinted acrylic and give it a dip! :D
Erik Hardtle
Post by Erik Hardtle »
Hi bouys and gulls,
- I do not use it on the non-skid surfaces (excpet the one between the two top windows).
- I use it on every smooth surface... the top, sides and hull. (I use rustoleum on the bottom! 8) )
- I used to do all the windows... but it will make it blurry looking out from the inside. Now I just do the two front top windows and keep the side windows clear.
Hope that helps!
I just ordered a kit. 8)
Erik Hardtle wrote:Hi bouys and gulls,
Hope that helps!
Herschel
Post by Herschel »
I used the NewGlass2 last year for the first time. I was very pleased with the results, but the initial 6 applications were a little tedious. It was July in Florida so you can imagine the temperature. A year later the topside needs the annual redo, which the company said could be done with just 2 coats. I covered every square inch of my boat from the waterline up, including the non-skid areas. I have had no problems with those areas being just as secure as before, and, as I said, I put six coats on initially. I think it is a good product, and I have no reservations about using it on any surface on the boat. 8)
kevinnem
Post by kevinnem »
I love being that guy that respond to really old posts.
How many coats do you get (bottom ½ or full boat) out of one bottle. Or .. How much of a bottle do you use per coat?
Erik Hardtle
Hey all,
I just did the annual re-apply to all the smooth surfaces (hull, sides and top windows... minus cockpit) with 4 coats and used a half a bottle. Took me 15 minutes (I was grilling in between coats... hehe)
Looks like a new shiny boat again!
I guess I should give that stuff a try. It's just getting too chalky on the decks, so I suppose I have nothing to lose. The hull still looks pretty nice though. 8)
Wind Chime
Post by Wind Chime »
Erik Hardtle wrote:Hey all,
Erik,
Do you do anything at all between yearly touch-ups?
Do you have to do any special prep before the annual touch ups?
Also, during the year do you still wash the boat with soapy water?
Mac26Mpaul
Post by Mac26Mpaul »
Does the gelcoat (particularly the black) not oxidize through this stuff at all then?
Thanks
Erik Hardtle
-----> Not from what I can tell... except that black strip curve between the top and side window... I have had to re-wetsand (600+ grit) it lightly one year.
-----> nope, just wash and let the boat dry. (oh, and patch the holes from my docking procedures! hehe)
-----> nope, just wash. 4 years ago I did strip it all off with the pre-treat (really easy!), cuts down on the buildup and drips I did not catch.
-----> yup! I use Tilex in the cockpit area since I don't newglass2 the cockpit area... cause I'm lazy.
Hope that helps!
Erik
From reading around the forums (other fora; not the much smarter folks we have here :wink: ), there's some talk of Newglass2 yellowing, and Polyglow not. I take it that's not been your experience?
Also, is it really slippery, particularly on the deck?
Erik Hardtle
I only do the smooth parts of the top deck, doesn't seem to be any more slippery than without it.
I have not noticed any yellowing... here is what my boat looks likes now. I'll let you all be the judge. (check out the black area on Compromise and mine)
