Page 2 of 2
Re: Where is the &^%$#! leak coming from?
Posted: Mon May 27, 2013 8:53 am
by Hamin' X
There has been one case of the compression post corroding, that I know of. Easy to check. Have a look at the thread here:
http://www.macgregorsailors.com/forum/v ... post+water
And welcome aboard, Tony.
Posted: Mon May 27, 2013 9:33 am
by K9Kampers
I still experience leaking at the chainplates, but have not yet attended to it as the leaking affect has been minimal. This issue has been discussed greatly and is in the archives.
I have had internal-source water leaks... the original collapsible water containers have either leaked thru the fill cap been punctured. I also had a 5 gallon solar shower stored in the bilge under the dinette table that punctured on a fiberglass burr.
Now when the head holding tank leaks on the :macx:, at least the spillage is contained in the head floor pan, and you KNOW where THAT leak originates!
Posted: Tue May 28, 2013 7:46 pm
by Tony E
Thanx for the welcome Rich. I am finding this site great and helpful and the people very friendly. I already made a few Mac friends around where I live so that's great and thanx again for the welcome :D
Posted: Tue May 28, 2013 8:10 pm
by hschumac
My biggest water source was the ballast tank plug. The rubber was old, not a good seal, and when filled you would see some water surge out around the plug and into the bilge. I never noticed it because the plug was always covered by the step. Only when I removed the step and was under way with some heel or waves did I notice it.
Posted: Tue May 28, 2013 8:43 pm
by dlandersson
West Marine - or any place that sells RV parts - has the plug. 8)
hschumac wrote:My biggest water source was the ballast tank plug. The rubber was old, not a good seal, and when filled you would see some water surge out around the plug and into the bilge. I never noticed it because the plug was always covered by the step. Only when I removed the step and was under way with some heel or waves did I notice it.
Posted: Wed May 29, 2013 2:49 pm
by dlandersson
And in fact, today, I replaced the "bellows" on the Porta-pottie (not too hard) and the hose from the sink to the thru-hull - which was a pain in the a#@ to get to and undo the clamps. The port sink thru-hull appear to be just rudimentary. Definite moisture at the bottom of the bilge (port side, under the galley). Thru hull appeared okay, so I put new hose, clamps and silicone sealant (not 5200 which the salesperson was trying to sell me). The 3M sealant was listed for thru-hulls - and is more flexible than 5200.
Time will tell if it works. 8)
tkanzler wrote:If the actual thru-hull is shot, I wouldn't even bother trying to fix it. I'd just bore it out and install a real thru-hull. If the hose is shot, then a new hose is easy enough to put in, once you can get to it, which might not be so easy. :?
Or it's something else altogether. :D
