Outboard mystery problem ? ? ? ? ? ? ? ?
THE CUSCUS
Re: Outboard mystery problem ? ? ? ? ? ? ? ?
Post by THE CUSCUS »
I'll take a stab here. Do these motors have a low oil pressure cut-off? At the higher rpm you might be starving the sensor for a number of reasons( low oil level, worn pump, clogged oil passages). I know nothing about big outboards, but alot of commercial vehicles have such devises to save the motor if there is an unexpected oil pressure drop.
island808
Post by island808 »
Ppossibly, I can't recall an engine cutoff with low oil pressure on cars but a car isnt going to kill you if it siezes miles from home. good thinking.
Searching reveals it should be a warning light. Only cutoff I can find is the lanyard. Stories from racers talk about changing the rev limiter... Not a rev cutoff. But the engine is older carb model.
Crikey
Post by Crikey »
What particular module do you have? :|
Here's their manual download pages:
http://www.tohatsu.com/tech_info/manuals.html
Here's a link to the MD 50A manual:
http://www.tohatsu.com/tech_info/own_ma ... B_TLDI.pdf
I didn't look at everything but couldn't immediately find anything specific - have a look.
Ross
rpasca02
Post by rpasca02 »
If it is a CDI engine it is likely the kill switch/wire and the over-rev limiter. Mine failed recently and cut the engine. Once I disconnected no problems. These boxes fail on occasion. Again if CDI the stator/trigger are super simple and you'll get spark.
