Re: Nissan NS5B 5hp Outboard
Posted: Tue Aug 12, 2014 9:41 am
So - if there's a shear pin, would it be #14? They call it a clutch pin.
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=23363
If that pin sheared, it would cause the symptoms you cite, but a shear pin traditionally sits outside the gear case where it can be easily replaced. I happen to have been inside my Nissan 4HP case to replace ground up gears when I hit a wire fish bait mooring at speed. That pin (14) is holding the clutch onto the prop shaft. If it is the only thing that went, it's easy to replace.NavySailor wrote:So - if there's a shear pin, would it be #14? They call it a clutch pin.
BTW, I notice several bits of advise about only using premium gas. To my understanding, this may have been true 30 years or so ago but for a long time, Federal law in the USA has mandated that all grades of gas have the same level of detergent and similar additives. The only thing premium gas has is a higher octane rating - this does not have any performance differences except it is not as combustible as lower octane fuel from the point of view it resists pre-detonation longer. Unless the engine has a compression ratio and timing that requires premium to resist pre-detonation, using premium is a waste of money.
Thanks very much for the info - and I always feel lucky!seahouse wrote:When you manually rotate the shafts, apply resistance to them at the same time (like a vice grip and a rag) to make sure there is no slipping, instead of just turning them. Then you can be certain they're solidly connecting.
From the diagramme it looks like one source of slippage could be between part 8 (what material is it made from?), which appears to engage the spline, and part 7 (prop) which appears to have a cone, or releasing taper that engages a mating face on 8.
Maybe the prop nut was not tight enough (?) or was bottomed out(?) before, if it relies on this tension for torque and shock absorption. That would give you the symptoms you're having (among other things).
Not to discourage you, but depending on how long there was water in the gear oil (that's what the brown “mousse” is, rust, probably the bottom layer) the bearings might be bad, or ready to fail. How “lucky” do you feel?![]()
Spin the prop while applying hand thrust one way and then the other to see if you can feel any roughness in them, if you can't inspect them visually. That can also be an indication that the seal(s)also need(s) replacing; they're letting water in.
The parts diagramme really doesn't give enough detail to tell too much more. There are different ways the shaft could be contained, circlip or other retaining ring, or a threaded ring needing a pin spanner...? But it will have to withstand the thrust when in reverse.
Good luck!
Interesting - I never asked a questionseahouse wrote:BTW, I notice several bits of advise about only using premium gas. To my understanding, this may have been true 30 years or so ago but for a long time, Federal law in the USA has mandated that all grades of gas have the same level of detergent and similar additives. The only thing premium gas has is a higher octane rating - this does not have any performance differences except it is not as combustible as lower octane fuel from the point of view it resists pre-detonation longer. Unless the engine has a compression ratio and timing that requires premium to resist pre-detonation, using premium is a waste of money.
A very good question.
The higher octane rating of premium gas can come from the addition of ethanol (bad- the politician's choice) which has a high octane rating itself, or from other additives and ingredients (good- the chemist's choice), or a combination of both (meh)!
Either A)Interesting - I never asked a question
