Wind Chime wrote:Does anyone want to take a crack at reviewing: free floating grounding for A/C verse D/C, and also ground bonding.
A/C ground to shore - D/C ground to battery - no bonding on Mac's?
Bond them.
http://www.safeelectricity.org/componen ... ticle/1589
What killed Lucas Ritz was a small boat rafted to a big boat, with an extension cord between them providing power to the small boat, and the DC system not bonded to the AC system. A chafed hot wire energized the -DC bits, which then leaked into the surrounding fresh water, creating a voltage gradient radiating out from that point. Human bodies have a lower DC resistance than fresh water across the same distance, so more current flowed through him than through the water around him, with enough current through him to paralyze him. I believe he was actually electrocuted, but most folks in the same situation drown when they can't move.
There's a graphic at the 6:00 mark that was used in the original presentation on this, with a detailed explanation, but I don't know where to find that (different) video at this time. Around the 9:00 mark starts a little bit of technical discussion with a few slides of bad wiring, but the other video (if I can find it) has much more detail on this.
My FIL tells me it used to be common practice to snip the shore power ground because leakage current from
the other guy's boat would eat up their props and shafts and other metal under the water.
I sent him the Ritz presentation for his Power Squadron flotilla a few years back, and he commented to me on how almost everyone there agreed that it was 'just the way it was' back then, and many (maybe most) were surprised about the dangers, including ESD. Granted, it's mostly a bunch of older gentlemen and their admirals, but it is/was the prevailing 'wisdom', if you can call it that.
Ahh, here it is. It was a long(ish) webinar, but worth watching.
http://www.abycinc.org/whyabyc/esd_I.cfm
