Will this hurt the motor?
- BOAT
Re: Will this hurt the motor?
Robert - you have an autopilot - is there any chance your boat will surf on AP - if that were possible it would make a long distance ocean crossing possible.
Lots of folks have done that, including me, and I have to tell you, performance is much, much better even with the cheap-o assym that was an option on these boats, as compared to wing-on-wing.BOAT wrote:I'm still a little unhappy with wing and wing with 'boat' and I really think an asym tied off somewhere higher on the mast would be less flapping around on the front of the boat.
https://www.youtube.com/watch?v=GHz-o9dXKIE
https://www.youtube.com/watch?v=2il9rwyETmg
As to the original question, the power into the lower unit is via a vertical shaft from the engine, but when it's off, it's not moving. All of the bits that move with the prop when the engine is off are running in oil, so nothing bad should happen to them when surfing.
- BOAT
Tomfoolery wrote:Lots of folks have done that, including me, and I have to tell you, performance is much, much better even with the cheap-o assym that was an option on these boats, as compared to wing-on-wing.BOAT wrote:I'm still a little unhappy with wing and wing with 'boat' and I really think an asym tied off somewhere higher on the mast would be less flapping around on the front of the boat.
Oh for crying out loud!! And you guys are not even using your mains!! The main sail is still in the sack!! OH MY GOD that has GOT to be the best way to run before the weather in a M boat! ONLY ONE SAIL!
Okay - I need to get one - so what is that? Is that the stock ASYM from the factory? It does not need any lazy jacks or poles, right? Any special tracks? Or does it just go right up the flagpole?
Then the next really big question for this post - can it hold up in heavy wind? What about decent wind and heavy sea? Is that sail the answer to our surfing needs?
- RobertB
Never been in the water with the AP. Not sure it would help much since the problem is the whole hull twists around as the wave passes the boat. I have experienced nearly 90 degree changes in heading.BOAT wrote:Robert - you have an autopilot - is there any chance your boat will surf on AP - if that were possible it would make a long distance ocean crossing possible.
Mine's an X, but it's the same sail. Stock factory cheap-o assym. I added a hound about 18" above the forestay hound. The M boats use a different style hound, but BWY sells them, and there are other sources.BOAT wrote:Oh for crying out loud!! And you guys are not even using your mains!! The main sail is still in the sack!! OH MY GOD that has GOT to be the best way to run before the weather in a M boat! ONLY ONE SAIL!
I didn't want to work that hard, so I didn't bother with the main. The admiral was reading, and I was just enjoying the ride. Beene was having a good ride, solo I believe, with the autohelm steering. There are many pics of that on the MMOR IV thread from 2013. Crikey took a lot of great pics. Look on the second to last page of that thread.
- BOAT
Okay - so what are the limits of the stock asym? (By the way - I already have the hound on my mast and the halyard - I have been using it all this time to haul up my jib sock and as a secondary forestay) GEEZ! I had no idea the boat was so well balance on a kite - I really need to get one and start flying i NOW so I can test it in heavy conditions.
Do you know it's wind limits? 20 knots, 25? (thirty?
probably not
- yukonbob
Except the forces being exerted on the entire transmission and drive train as you drag the fixed prop through the water. Kind of like dragging a car down the road in gear.Tomfoolery wrote:
I should clarify - I meant in neutral. Just the output shaft with it's two little dog clutches spinning, in oil.yukonbob wrote:Except the forces being exerted on the entire transmission and drive train as you drag the fixed prop through the water. Kind of like dragging a car down the road in gear.Tomfoolery wrote:
- BOAT
Yes, the motor will always be in neutral. So the prop will be turning a gear and some oil - I get it - does not sound like a big problem but really, based on what Tom said about the asym and based on what Highlander did on a stock boat with the board down less than a foot I think dragging the motor might not be required - it just might be a moot point now.
Still - the motor does make a pretty handy little drogue anchor and might even help the rudders do their job? (whoa - how about a big rudder you can attach to the motor just for sailing in storms?) That might be a neat trick and might save the other rudders from damage too?
Courtesy of Crikey. (Hope he doesn't mind)
Me rigging the spinnaker while the admiral steers under power. You can see the mast hound above the original. I also added a tack line to the extra hole in the stem fitting, after moving the forestay to the rearmost of the two holes (no length difference). The tack line goes through a few small blocks back to the cockpit, so I can adjust it.
Splitting off in two different directions, but with the same eventual destination - Toronto Island Park.
Pegasus, driving pretty hard. One of my favorite Mac pictures. This too could be you, BOAT.
- BOAT
Wow, that's great! So you have a bowsprit on Pegasus?? I don't have a bobstay collar on 'boat', how do i get a bowsprit on there? Do I need a bowsprit? (I guess i could mount a collar from an old double ender that's full of parts down at Minny's) Where did you get yours? Is that a donut sack on top of the sail?
So U r looking for one of these PuppiesBOAT wrote:Wow, that's great! So you have a bowsprit on Pegasus?? I don't have a bobstay collar on 'boat', how do i get a bowsprit on there? Do I need a bowsprit? (I guess i could mount a collar from an old double ender that's full of parts down at Minny's) Where did you get yours? Is that a donut sack on top of the sail?
http://i235.photobucket.com/albums/ee20 ... 010067.jpg
http://i844.photobucket.com/albums/ab1/ ... 010056.jpg
http://vid844.photobucket.com/albums/ab ... 010057.mp4
Been,s Boat Geoff & I having a fun day
http://vid844.photobucket.com/albums/ab ... 3d9c95.mp4
http://vid844.photobucket.com/albums/ab ... 942336.mp4
- mastreb
Sure it will. The EV-1 does a fantastic job of countering wave action to keep the boat straight, with both facing and following waves. It's got a 3-axis sensor that works to minimize pitch, yaw, and roll. Does a way better job than I could ever do. It even counters people moving around the boat really well. Makes the whole boat seem a lot less tender.RobertB wrote:Never been in the water with the AP. Not sure it would help much since the problem is the whole hull twists around as the wave passes the boat. I have experienced nearly 90 degree changes in heading.BOAT wrote:Robert - you have an autopilot - is there any chance your boat will surf on AP - if that were possible it would make a long distance ocean crossing possible.
