Page 2 of 2
Re: Finally Hot Water!
Posted: Fri Jul 03, 2015 12:04 am
by cptron
How much power does the tankless use?
Posted: Fri Jul 03, 2015 12:46 am
by vkmaynard
Just finished up and check out the system. Everything works perfectly.
The hot shower in the head was a long time planning. The shower sump cranked up no problem. Hot shower worked on the transom also.
Removed the AC from my Billy Box, disassembled it and shortened the power cord to custom fit the boat.
Going cheap and back feed the outlets with an inverter while on 12V. Just need to be careful to undo before starting shore power.
Shore power nice.
Victor
Posted: Fri Jul 03, 2015 1:45 am
by kadet
cptron wrote:How much power does the tankless use?
None they run on LPG :)
Posted: Fri Jul 03, 2015 1:50 am
by cptron
Coool er I mean Hoooot!!! 8)
Posted: Fri Jul 03, 2015 1:52 am
by kadet
Thinking of carrying one of these when I go for my long cruise next year, bit expensive but no install needed :)
http://www.ebay.com.au/itm/like/2519218 ... 107&chn=ps
Posted: Fri Jul 03, 2015 4:33 am
by vkmaynard
We have one of these in blue http://www.ebay.com.au/itm/COLEMAN-HOT- ... 1921861151
Heavy, awkward and uses a lot of water. Can't use it in the head. We carried it several times then gave up. Hopefully your back is in great shape.
Victor
Posted: Fri Jul 03, 2015 5:06 am
by kadet
vkmaynard wrote:We have one of these in blue http://www.ebay.com.au/itm/COLEMAN-HOT- ... 1921861151
Victor
I have an :macm: what head :) Aquacube only weighs 9.3KG so will see 8)
Posted: Fri Jul 03, 2015 5:39 am
by Mac26Mpaul
Where you going on this long cruise that you will need hot water Kadet? You're a QLDer, you need a slushie maker in the boat, not a hot water system :wink:
Posted: Fri Jul 03, 2015 7:54 am
vkmaynard wrote:Just finished up and check out the system. Everything works perfectly.
Cool. That is a nice advantage of the X head, the ability to add a shower.
Posted: Fri Jul 03, 2015 10:15 am
by Wind Chime
Victor,
I like the placement of your outlet behind the dinette table (photo below).
Was there enough depth behind the the A/C plate to install a "shallow gang box", or are there open wires at the back of the plug-in?
Post by vkmaynard
What changes did you do in the head to add the shower?
- did you drill a hole in the head sole to drain water into the bilge sump?
- did you add a shower curtain and rods?
Some picture of the head shower changes would be great.
Posted: Fri Jul 03, 2015 3:13 pm
by kadet
Mac26Mpaul wrote:Where you going on this long cruise that you will need hot water Kadet? You're a QLDer, you need a slushie maker in the boat, not a hot water system :wink:
Brisbane -> Maroochydore -> Wide Bay -> Hervey Bay -> maybe onto Lady Musgrave, in Winter with female crew so some comfort might be needed :)
Will depend on weather time available etc.. no fixed plans could even spend the whole time gunkholing around Fraser.
Posted: Sat Jul 04, 2015 12:48 am
by Mac26Mpaul
Ahh, nice, provided my missus finishes her latest degree by mid 2016 as planned, we are going to do 4 weeks cruising the
Whitsundays next September 8)
If they are good, my crew will get the usual, the boom hauled up and a solar shower hanging from it in the cockpit :D
Posted: Sun Jul 05, 2015 10:44 pm
by vkmaynard
Wind Chime wrote:Victor,
No gang box behind the dinette table outlet. Just open wires that nothing will ever touch. Ground fault on all circuits. Tried to add the USB outlet over the dinette but too deep. Installed that one in the galley.
The shore power worked great for. What a nice upgrade. The kids immediately used every outlet in the boat and really enjoyed no extension cords everywhere.
Victor
Shower mod: http://www.macgregorsailors.com/modt/in ... ?view=1214
Posted: Mon Jul 20, 2015 11:35 am
by vkmaynard
First actual use this weekend of the hot water sytem. Work perfect.
At one point the boat grounded on the beach. I walked up to it several hours after two head showers on one heat up and washed off using the heated transom shower. Plenty of hot water with a one time warm up.
My kids have zero ideas about conserving water on a boat.
Victor
Posted: Mon Jul 20, 2015 11:48 am
by u12fly
Victor
Ha ha ha :D :D :D There may be no cure for that :? Well until they grow up! :wink:
