dlandersson wrote:FWIW, a PO on my X appeared to spare no expense on mods, and that is exactly where my shore power connection is also.
Just for the record, mine is there as well, and even appears to be the very same type of squared-bezel plug outlet with a reasonably watertight flip-cover. Right there amidships and well above the waterline would seem to be a pretty good place for it, easily accommodating most any power box placements one may encounter at a dock, yet still handy enough for a generator at the stern...handier at least than an outlet in the anchor locker, anyhow.
A previous owner may have put mine there, though I'd have guessed it was a factory installation. Now I am not sure. The AC power panel is quite nearby in the cabin on the wall above the "pizza oven" berth, above and aft of the little galley seat, which is good. You don't need long lengths of live AC wiring slinking around through the bilge or walls if you can help it. That's just more opportunities for mayhem. Not being an electrician and taking some good advice for non-electricians like me from Don Casey's book,
Sailboat Electrics Simplified, I had the shore power setup checked out by the pros at a local marine repair shop before even using it. I'll happily fuss around with the 12V DC, but not the 120V AC "
Welcome to Eternity" stuff.
As for the rest of the AC layout, the PO had mounted a couple of nice dual GFCI-style AC outlets (one on the forward galley island wall facing the settee, and another in the wall of the forward seat under the table--next to a handy 12V outlet too). He also put one of those ProSport dual battery charger/tender gizmos under in the storage area under the settee, which can tend to my dual batteries (both in the storage area under the little galley seat) if it's plugged into the aforementioned GFCI outlet in the forward-facing galley island wall. Although I'm not to credit for it, it just seems to me a really sensible layout, placing those AC outlets well away from the companionway and any foul weather that might blow into the cabin.
