Love the slide up to the ceiling of the table to get it out of the way.
The bench seat is a great way to make a much more comfortable sitting area.
How have you found it to use over the past 5 years?
Best Regards,
Over Easy
that mod has me thinking.. I would do the round table but add 4 circular holes for cups / mugs.OverEasy wrote: ↑Mon Nov 22, 2021 9:56 am Yes! Very nice renovation of the dinette Geraghtyr!
Best Regards,
Over Easy![]()
Teak and Holly boat sole plywood. Got it from a place in Florida. (All the boat construction stuff is in Florida now because all the boat builders moved there). I guess the boat builders use it to line the sole of the boat cabins in their big factories. Kevin knows more about the stuff than I do.
Let me take the questions in reverse order: "Draining into the main bilge" for the shower is not an option.OverEasy wrote: ↑Sat Dec 04, 2021 9:49 pm That flooring looks great!
How thick is it?
Is it solid wood or is there a backer material?
On to your companionway shower….
Is it draining into the main bilge and then pumped overboard?
Or is it collected into a grey water holding tank to be pumped out at a sanitary facility?
What happens is the water shoots out of that hole into the motor well:is it collected into a grey water holding tank to be pumped out at a sanitary facility?
