Watch out that you don't bump too hard and drop the centerboard below the bunks. I've done that twice, the last time being when I hauled it for the winter. It's still hooked in front of the bunk, so I have to either remove the mounting bracket and reposition it, or maybe I can jack the bow enough to get it to clear and pull it back up.
Why did it do that you ask? Because (I think) the first time it happened, I had the CB most of the way up when I made my run onto the trailer, but forgot to pull it up the rest of the way as it went on. Or after, since it'll just fold, but either way, I forgot.
This time, I know I had pulled it up, but the line either jumped out of the cam cleat, or I helped it jump out some how, which is the more likely scenario. But when I 'mac bumped' it, it got hooked in front of the middle bunk. Again.
From the first time:
I have a piece of angle that I intended to bolt to the front of the cross member, with a 2-by block to catch the CB if it falls, but haven't gotten around to it yet. I think it's time to get around to it.
