Well I'm back in Calgary after spending a good portion of my summer holidays at the family cabin on Babine Lake BC. Fortunately we were spared the wildfires and smoke
compared to other areas in BC. I achieved most of the mods I set out to do including sea trials and break in procedure on the new Honda BF50D. I was kept so busy with the mods
on shore and sea trials for the motor that I didn't have time get the sails up. It was a power boat summer.
I'll share with pics....lots of em.
New BF50D
https://photos.smugmug.com/Boats/New-Ma ... 733-XL.jpg
Transducer for my old Humminbird 565. I also replaced the old cracked seal on the transom valve.
https://photos.smugmug.com/Boats/New-Ma ... 734-XL.jpg
New thru hull boot and throttle/shift cables. Cables are 13' and I'm ok with them up in the air like that without stepping
or tripping over them.
https://photos.smugmug.com/Boats/New-Ma ... 735-XL.jpg
https://photos.smugmug.com/Boats/New-Ma ... 775-XL.jpg
Helm.
https://photos.smugmug.com/Boats/New-Ma ... 736-XL.jpg
I'm happy with my remote installation with the trim orientated as it should. It took a bit of fiddling with the metal extrusions
and plastic spacers. I added an extra fastener from the standard 3 (total 4) to make it all more rigid.
https://photos.smugmug.com/Boats/New-Ma ... 737-XL.jpg
https://photos.smugmug.com/Boats/New-Ma ... 738-XL.jpg
https://photos.smugmug.com/Boats/New-Ma ... 739-XL.jpg
https://photos.smugmug.com/Boats/New-Ma ... 740-XL.jpg
Notice the motorcycle fork boots that I used as a conduit for the control cables.
https://photos.smugmug.com/Boats/New-Ma ... 741-XL.jpg
https://photos.smugmug.com/Boats/New-Ma ... 756-XL.jpg
On to the electrical. Group 24 batteries. The #1 start battery is lead/acid which came with the boat and is fairly new. The #2 house
battery is a new AGM deep cycle.
https://photos.smugmug.com/Boats/New-Ma ... 744-XL.jpg
https://photos.smugmug.com/Boats/New-Ma ... 743-XL.jpg
Notice the Voltage Sensing relay or combiner on the left made by Yadina. No need to switch the Perko battery switch when up and running.
https://photos.smugmug.com/Boats/New-Ma ... 776-XL.jpg
I really like the power monitor on the right. All for about $10.
https://photos.smugmug.com/Boats/New-Ma ... 742-XL.jpg
Following taken through the access hole once the stove is out. Besides the fuse panel you can see the batteries on the left,
the shunt for the power monitor, negative bus bar and a 50 amp resettable fuse.
https://photos.smugmug.com/Boats/New-Ma ... 747-XL.jpg
Looking aft.
https://photos.smugmug.com/Boats/New-Ma ... 753-XL.jpg
Side view of the battery installation. The #2 or house battery is held by the SS bracket and the #1 battery is secured to the tray
with the Moeller battery tray to the platform with fasteners. The rubber shock mount you see on the lower right (2 total) against the curved hull are from
an old China made 2000 watt inverter generator. It all seems secure. We'll see how it all holds up in the ruff stuff.
https://photos.smugmug.com/Boats/New-Ma ... 752-XL.jpg
New SS cleats and hatches port and stbd.
https://photos.smugmug.com/Boats/New-Ma ... 757-XL.jpg
New SS cleats and bow anchor roller from BWY.
https://photos.smugmug.com/Boats/New-Ma ... 760-XL.jpg
At the front of the anchor storage box I installed a piece of surplus aircraft track fitting. No excuse now for losing
all my chain and anchor.
https://photos.smugmug.com/Boats/New-Ma ... 763-XL.jpg
https://photos.smugmug.com/Boats/New-Ma ... 765-XL.jpg
LED light over the table. I simply wired it to the original light adjacent.
https://photos.smugmug.com/Boats/New-Ma ... 766-XL.jpg
Are these ever bright and give out a great light.
https://photos.smugmug.com/Boats/New-Ma ... 767-XL.jpg
It looked like a pain to run a light over to the lavatory so I hung a qty 6 AA battery operated LED light. Slick and bright.
https://photos.smugmug.com/Boats/New-Ma ... 770-XL.jpg
I really love working on this boat. I've got some of the big stuff out of the way obviously. It's really endless what you can do.
The passion is still there on this 20 year old boat.
