Re: I have an electrical question.
Posted: Thu Mar 22, 2018 8:57 am
I don't think your supposed to charge lithium batteries from the ETEC alternator on the OB - well, unless the lithium battery is like a really really big BANK of batteries (like the way they do them in a Tesla car) or if it's like a really BIG battery - like in a Prius, or a Chevy VOLT car. The Prius has a special alternator set up so the battery does not get high voltage when full even though the engine is not supposed to start when the battery is full. The guy that TRIED to 'splain it to me
(unsuccessfully) said that the batteries will be ruined fast if you overcharge them. I was too stupid to understand him but I can repeat some of the things he told me.
He said lithium batteries should not be charged from a voltage source that is over 14 volts - unless the batteries are pretty dead. They said that if the lithium battery is almost fully charged and you hook it up to your ETEC60 it will overcharge the battery because the ETEC alternator puts out over 14 volts at full throttle. So that means you need to disconnect your lithium battery from the OB when your underway or you might overcharge the battery.
Pretty sure the regular batteries can take a 14 volt charge for many hours on end but apparently you can't do that to a lithium battery.
Anyways, he said it's a bad idea, but I'm sure you guys know more about this than I do.
I did have a question for TOMFOOLERY - are we supposed to connect the neutral in our AC system to the negative equipment ground in the DC system??
I did not do that - are you saying we SHOULD, or we SHOULD NOT? I got confused on that one.
And what about the Equipment ground on the AC system? (Like the ground wire on the AC receptacles - aka - the little green screw and the green pigtails - the GREEN wire - should THOSE be grounded to the same DC equipment ground too???
I have green wires on all the AC stuff that grounds the receptacle boxes and junction boxes and stuff. I ALSO have green wires that are grounds for all the DC stuff. I don't think I have those two systems tied together right now - should I?
