what kind of stove do you use?
Re: what kind of stove do you use?
BWY "Cruising package" came outfitted with a butane stove.
It works very well. Very hot and convenient.
We mostly use it only to make coffee. The Magma gets most of the cooking duties.
I don't like lighter than air gas stoves, but we store the bottles carefully and always have ample ventilation before using it.
Natural gas is lighter than air, though, at 0.6-0.7. Maybe that's what you're thinking of.
Tom
Be seeing you . . .
Be seeing you . . .
- Jimmyt
Tomfoolery wrote: ↑Mon Nov 16, 2020 11:37 am [quote=Russ post_id=346081 time=<a href="tel:1605547709">1605547709</a> user_id=7207]I don't like lighter than air gas stoves, but we store the bottles carefully and always have ample ventilation before using it.
[/quote]
Russ,
You gotta start proof-reading your posts. You throw him one straight down the middle like that and Tomfoolery will hit it right out of the park every time.
That's my problem with posting before the second cup of coffee. Bad proof reading.
HEAVIER than air.
But Tom always blesses us with more knowledge. Gotta love engineers.
- Inquisitor
I've read quite a bit on the subject (on this site) and the flame wars that start over stoves...
alcohol, pressurized or not, butane, propane, kerosene, diesel, butt gas...
Some people feel VERY righteous with their opinion. For some reason, other sailboat sites are less worried about propane.
If I were to put a "camping" stove inside, BUT... BUT...
- used ABYC certification procedures for lines
- an external tank (the little 1 lb Colman type tanks) since I can't fit the standard 20# versions.
- Had an external valve.
- Had a fiberglass lined tray around it so any escaping gasses were funneled to one place
- did full gas leakage tests
- And a propane alarm at the bottom of said tray
When I installed my gas range, I ran a fuel line (Mfg. recommended gas line) from the galley along the aft berth, and up and out by the motor. There I installed the adapter that the 1 pound propane canister screws onto.
I store the canisters in a pouch that suspends from the mast arch. It is especially designed to hold three canisters.
I only use the range when either at anchor, or docked, and the motor is not running. Because of my infrequent use of the stove top, I don't have any fear of heavier than air gas build up. I could always light a candle in a bilge to see if there is any leakage
When I was a boy, my friends used to sing a ditty to the tune of my Bonnie lies over the ocean.
My Bonnie looked into a gas tank, the contents she wanted to see. She lit a match to assist her; oh bring back my Bonnie to me.
- Inquisitor
You crack me up!
... but I hadn't thought about anywhere besides the tank alcoves. That's a great place. I was thinking about a 6 or 9 gallon tank on the other side to permit storage and use of the 1lb propane. This way I could still do two full 12 gallon tanks. Thanks!
If you want to go all ABYC-ish, install a 12VDC fuel solenoid valve at the gas bottle, with a remote toggle switch at the stove top. They're normally closed, energized to open, and that way you can energize it, do what you need to do on the stove, then shut it back off. No risk of fuel leakage back into the cabin, and in an emergency you can shut the switch off to kill the gas.
My keel boat had a lighted toggle switch, so there's no way you didn't know the gas was on.
Tom
Be seeing you . . .
Be seeing you . . .
- Inquisitor
I started looking at those solenoids. One on Amazon was listed for Propane, but one of their customers complained that his was leaking. Company evaluated his rig and determined that the very low pressure used (6 ounces of pressure) after the regulator was not enough to seat the valve. They retracted their propane recommendation. Point being...
1) can you recommend a brand that is OK
2) Is something like this a good idea https://www.amazon.com/Motorized-Stainl ... B06XWZRLJ1
a) Doesn't rely on back pressure to keep sealed.
b) Doesn't use any electricity after opening and closing.
c) Stays in last position.
d) No chance of burn-out from being electrically kept open continuously.
- Jimmyt
I would recommend using valves that are UL listed for propane shutoff duty (or other equivalent listing/certification). The valve Tomfoolery referenced is UL listed for the duty. 12volt D.C. versions aren't too common. 24v ac and 120v ac are pretty easy to get.
West Marine sells one for low pressure duty, but I can't find any listing/rating info. https://www.westmarine.com/buy/trident- ... e--9457318. One would assume West Marine wouldn't sell a valve that wasn't listed, but who knows these days?
The concept of a safety shut off valve requires that it fail closed. If you are worried about leaving the switch on, use a timer switch.
I placed the canister far outside of the cockpit for safety reasons, but these posts have me thinking about what safety features are built into the stove itself to prevent, or stop gas leakage.
This is the unit I have.
It does have a system built in, in case there is a flame burnout. I've never tested it.
Page seven in the manual.
- Jimmyt
Great safety feature Ray! Looks like you got good bang for the buck on your cooker!
- Jimmyt
